Can Pi be used in the cold weather
Posted: Sun Feb 22, 2015 9:44 pm
by raymate
What is the lowest the tempurature you can use a Pi.
May want to set up a Pi to control some lights and garage door opener, but our garage can go down to -20 in some winters.
Would the Pi using a WiFi dongle along with some relays work in that kind of cold
Likewise what is the hottest it can run.
So I guess whats the operating temp?
Re: Can Pi be used in the cold weather
Posted: Sun Feb 22, 2015 9:46 pm
by liz
http://www.raspberrypi.org/penguin-lifelines/ <- should answer your question for you - and them some!
Posted: Sun Feb 22, 2015 10:10 pm
by raymate
liz wrote:http://www.raspberrypi.org/penguin-lifelines/ <- should answer your question for you - and them some!
That certainly does, -40 thats cold, so for what need it will be fine.
Posted: Sun Feb 22, 2015 10:12 pm
by gordon77
For electronics moisture is normally more of a problem than cold.
Posted: Sun Feb 22, 2015 10:25 pm
by Mequa
gordon77 wrote:For electronics moisture is normally more of a problem than cold.
Would it be useful to surround the Pi electronics with a desiccant such as silica gel, in order to absorb moisture in a cold and damp environment?
Posted: Mon Feb 23, 2015 1:33 am
by septantrionalis
I have 2 Raspberry Pi's (first generation) sitting outdoors as motion sensing surveillance camera's. The past winter, they frequenct below 0 degree Celsius temperatures. In fact, I took this screen shot of the temperature as displayed by the shell a few weeks ago when the temperature dipped to about -10 degrees Celsius outside.
The only problem I ran into was when it got too cold, the Raspberry Pi would just stop working. I found out that the SD card wasn't making connection with the Raspberry Pi. I guess the cold caused the metal connector to shrink back? I dunno. I wedged some paper in there and that solved the problem. I don't know if this is an issue with the B+ or Raspberry Pi 2.
Posted: Thu Nov 12, 2015 7:42 pm
by Desert_Temp
That article pretty much summed it up for me. I was worried about cold weather too. My Pi hit 14F last night.
