WarrenG wrote:Hi Folks,
I'm looking for someone to design, build a Raspberry Pi project to communicate with industrial machines for my own personel use. I run various engineering projects throughout the UK for industrial customers and I'll think it great to be able to throw my big bulky laptop into the bin so hence this project .......
The Pi device needs to be small, compact and neat as possible (external case/shell can be done by me) with built in rechargeable power source, LCD monitor, and connectivity to either 25 pin RS232 and/or standard USB port . The software needs to be simple, send & receive text data, also the option to view that text on the LCD screen . Ideally with built in storage of minimum 1GB.
Ideally you need to live around the Shropshire/Staffordshire/Midlands area, Once the project is completed then I would pay you.
If your interested please post your location, estimated price & target completion date & I'll be in touch .
Regards
Warren
I think what is confusing people is the need to have a portable device that can send and receive text data and not explaining properly the reasons why.
If I may elaborate a little on your behalf. Please tell me if I am wrong though. Being an ex-engineer I am somewhat familiar with the technical difficulties you face. Saying that you need something simple and then say it's main requirement is just to send and receive text data is a bit of a red herring and it is confusing people into thinking that current tablets or netbooks will suffice. This i believe is not actually the case. As part of an engineering team, my role was to provide the hardware to communicate with various industrial machines, in this case Panasonic BGA surface mount machines and conveyor line control boxes. Configuration data, setup data, sensor data, error data was all sent and received in text format via serial communication. Some of the machines had 9 way or 25 way serial connectors on them. Other members of the team wrote the communication software. If i am right, I believe this is the type of thing you deal with, hence why it is not just a simple case of a device being able just to send and receive text data as it is slightly more complicated than that. Am i right?
Many industrial machines still use serial as the method of communication, heck, even my Honton BGA rework machine uses serial communication so I can control heat profiles and it's just under 2yrs old. This makes using tablets out the question because they are not able to connect to serial connected devices. The best device to use is of course a laptop BUT the ones that have the communication protocols required are to old to and too big. That is one reason why you find many manufacturers still have very old laptops to date because they connect seamlessly with the industrial machines they use and to try and find a modern day equivalent would be too costly to research in time and manpower.
Any modern device used today must have cross compatibility with older communication methods, such as serial but unfortunately no laptop manufacturer builds a netbook or a small laptop with serial ports because they consider it outdated. There are companies who make inter-series serial communication cables but they are extremely unreliable, I know as I have tried many of the USB to serial adapters and when your being employed by a customer to handle data from their machines, the last thing you need is reliability problems. Hence the issue Warren finds himself in having to use an old and large laptop.
There are already serial devices made for the Pi, this is one of them
https://www.abelectronics.co.uk/product ... al-Pi-Plus . A 25way to 9way RS232 cable is all that is then needed.
One method that could be used is using the Pi as a remote connection box to the industrial machines. The Pi is connected to the machinery either by USB or the serial port and Warren would then use a normal lightweight laptop to remotely connect to the Pi via WI-Fi. There are lots of web pages that explain how to use remotely connect to the Pi. This would negate the issue of having to buy a screen, keyboard and mouse for the Pi and have it all cased up.
So you've got the option of having a remote setup or purchase individual parts to make the Pi in to a portable laptop.
Rog
