TV and RPI
Posted: Thu Feb 19, 2015 2:24 pm
by naselloj
Help needed please.
Downloaded from torrents this file (raspbian_2gb.img) for which I found by doing a search for RPI Raspberry Pi raspbian wheezy 2gb image with deluge couchpotato sickrage on Google.
Description
***UPDATED***
raspbian wheezy 2gb image with deluge couchpotato sickrage (sickbeard) minidlna installed
user = pi
password = raspberry
ports:
deluge = 8112 (no passwd)
couchpotato = 5050
sickbeard = 8081
minidlna = 8200
change deluge to 'use compact allocation' for stability
You need at least 4gb sd card, loaded image to sd card with no problem then put it into RPI and started everything I think loaded because it asked for a login and password so entered Login pi and password raspberry then it came back with Type 'startx' to launch a graphical session so I typed this
pi@raspberrypi ~ $ startx it came back with
-bash: startx: command not found
pi@raspberrypi ~ $
I am at a lost for now there is no documentation for me to follow and I am trying to get something to run on a RPI for auto TV downloads, have tried to install Sonarr (Nzbdrone) but there also cannot get it to work.
Hoping someone can please help me with good documentation or an image of Sonarr for the Raspberry Pi . Again thank you and any help is appreciated .
JGN
naselloj@yahoo.com
Re: TV and RPI
Posted: Thu Feb 19, 2015 3:56 pm
by expandables
There sames to be no graphical interface install for the raspbian wheezy you downloaded or you can try start lxde. Download latest Raspbian which defintely has a GUI installed from here
http://www.raspberrypi.org/downloads/
Instructions to install Sonarr here
http://www.htpcguides.com/install-sonarr-raspberry-pi-mono-310/
:mrgreen:
Re: TV and RPI
Posted: Thu Feb 19, 2015 4:19 pm
by naselloj
Thanks, I am a newbe so if I install Raspbian then how do I install the image without overwriting Raspbian?
I was said to try http://www.htpcguides.com/install-sonar ... -mono-310/, I have tried this about 5 Or 6 times
and it never finishes installing. I get it to install mono 3.10 and then when I try the rest of the install for Sonarr it does
not fine everything to finish the installation. I forget the errors that rec'd, but I can try again and mark down the errors
but after 5 or 6 times it gets long.
Thank you
Re: TV and RPI
Posted: Tue Mar 03, 2015 6:24 am
by naselloj
Hello
I have Rasbian installed on a RPI but can't fine a way
to merage another image so I can use the Rasbian graphical
interface with it. What I need is to run one image from
within another image, can someone please help?
Thank you
JGN
Re: TV and RPI
by naselloj
Hello
Thank you
JGN
