ajazam
Re: Building 24 Raspberry Pi2 Cluster
Fri Feb 20, 2015 10:33 pm
What are you doing with gnu parallel? I'm just curious. I'm definitely not one of the young ones :)
psutton wrote:We (well one of the young people) are doing this at the Torbay Pi jam, we don't have that many Pi's other than our own, to play with so starting off with a few laptops, (this works)
We need more resources for the Pi jam but also have no where to store stuff at the moment.
Work so far is in a rough write up here
http://www.dcglug.org.uk/cluster-mark-2/
We are using GNU Parallel which seems to be doing what we want, nicely,
I just wondered where this would fit in to the National curriculum for year 7, in terms of what skills are being developed that would fit in with what gets taught at year 7.
ajazam
Fri Feb 20, 2015 10:34 pm
I'll see if I can find some M2.5 20mm.
marked wrote:you might not have the right ones - you want M2.5 (two point five) which is between M2 and M3.
beagile
Tue Mar 03, 2015 9:41 pm
Hi kangmo,
just a short remark regarding "is there any easy deployment tool that I can use on Pi2? Docker seems not to be a good solution, as it requires x86 linux to run on top of Arm Pi2".
This is not true anymore. We just published a SD card image based on Raspbian that includes a ready to run Docker.
You can find our image and information about how to use it here: http://blog.hypriot.com/heavily-armed-a ... -1-dot-5-0
Govinda
- blog.hypriot.com -
dcaoyuan
Sun Mar 08, 2015 1:32 pm
Hi kangmo,
You may be interested in the akka cluster I'm building:
http://dcaoyuan.github.io/papers/rpi_cluster/
I posted some results on twitter too. @dcaoyuan
mvbakker
Sat Sep 26, 2015 4:00 pm
Kangmo,
Did it work? What are your results of the RPi2 cluster? :)
