zazas321
Raspberry PI 4 Touch monitor recommendations
Wed Sep 15, 2021 5:29 am
Hello. Could someone recommend me some decent touch 1920x1080 display monitors for Raspberry PI 4 for production environment. We use Raspberry PI 4 to run some processes in the factory. At the moment we use:
https://www.waveshare.com/product/raspb ... h-case.htm
The only bad thing about this display is that the connection ports are located on the side of the display which causes the cables to stick to the side too much. The solution would be to use 90 degree cables but we are not able to find a good supplier for those therefore we are looking for a display alternative.
Could someone suggest a display that would have a connection ports at the back of the display like a standart monitor instead of on the side?
aBUGSworstnightmare
Re: Raspberry PI 4 Touch monitor recommendations
Wed Sep 15, 2021 6:00 am
What about https://www.pi-top.com/start/touch-disp ... 01e6e048ba?
Smaller and requires some adapter (supplied) when used with a 'normal' Pi4.
Or ... Get an 'industrial ' product, i.e. https://iiyama.com/gl_en/products/prolite-t1633mc-b1/
zazas321
Wed Sep 15, 2021 6:47 am
From what I understand, the pi top 3 touch display does not have a standard vesa mount which we use to hang the monitor. The other display that you have suggested seems like a solid choice (VESA mount, connection ports at the back)
aBUGSworstnightmare
Wed Sep 15, 2021 7:10 am
you did not mention how you mount them :shock:
Yep, Iiyama would be my preference for an IA use case.
