anhsirk21
Cron sechduling to play music using mpg123 issue
Sun Aug 01, 2021 7:54 am
mpg123 having an issue with playing music at the scheduled time.
Current code on crontab -
00 07 * * * /usr/bin/mpg123 --shuffle /home/pi/Documents/Cron-task/music/*.mp3
cron shows up on syslog but nothing is played over the speakers.
music plays fine over the speakers but does not play with scheduled crontab.
thanks
GlowInTheDark
Re: Cron sechduling to play music using mpg123 issue
Sun Aug 01, 2021 8:46 am
As with all things cron, you need to get logging working in order to figure out what is wrong.
The short summary is: There's something different in the environment running in cron than when you run it manually.
Anyway, the following link may be interesting reading for you:
https://blog.devgenius.io/set-an-alarm- ... a6554d5e49
Poster of inconvenient truths.
Linux zealot and proud of it.
"nokcid" wants to date me.
hal8000
Sun Aug 01, 2021 9:06 am
As normal user, open a terminal and test your command with
If that command does not work, then there is some error in either your path or spelling (everything is case sensitive)
As crontab is run as root and root user has access to /bin/bin/ you can enter your crontab as:
   00 07 * * * mpg123 --shuffle /home/pi/Documents/Cron-task/music/*.mp3
pcmanbob
Sun Aug 01, 2021 9:40 am
Cron can be run as root using " sudo crontab -e "
or as pi user using " crontab -e "
It looks like the OP is running it as pi user.
anhsirk21
Try changing your cron line to this
00 07 * * * mpg123 --shuffle /home/pi/Documents/Cron-task/music/*.mp3 >> /home/pi/log.txt 2>&1
then after the time it should have run look in the file log.txt and see if there are any errors.
GlowInTheDark
Sun Aug 01, 2021 9:51 am
User has already stipulated that it works as expected when run interactively.
As crontab is run as root and root user ,,,
crontab(1) is (almost) never run as root. You run it as the user (i.e., user pi in most cases).
cron jobs themselves are run as the user from whose crontab files they are from. (Again, user pi in most cases).
thagrol
Sun Aug 01, 2021 6:51 pm
  • Which OS?
  • Booting to desktop or command line?
  • When it works interactively, was that via a local login or over ssh/vnc?
  • To the desktop or command line?
If you're running RPiOS with desktop it might be pulse audio related. AIUI, pulse only starts on login and is a per user/session process. Could be a lack of a pulse daemon or a permissions problem but with no log/error message it's impossible to say.
I'm a volunteer. Take me for granted or abuse my support and I will walk away
All advice given is based on my experience. it worked for me, it may not work for you.
Need help? https://github.com/thagrol/Guides
anhsirk21
Mon Aug 02, 2021 5:46 am
I am able to play music through my terminal but not with crontab.
would using sudo crontab -e make a difference?
W. H. Heydt
Mon Aug 02, 2021 5:59 am
thanks
About all I can say is that here is how I did something similar...
Crontab entries (the first line plays an existing track, the second line streams from our local Classical station):
45 06 * * 7 mplayer -volume 60 /media/pi/MUSIC/messiah/track_32.wav
58 06 * * 7 /home/pi/bin/runkdfc
Runkdfc also displays the stream metadata in a lxterminal window on the 7' RPF display:
#!/bin/bash
PATH=/home/pi/bin:/usr/local/sbin:/usr/local/bin:/usr/sbin:/usr/bin:/sbin:/bin:/usr/local/games:/usr/games
export DISPLAY=:0.0
lxterminal --geometry=70x7 -e mplayer -cache 512 -volume 60 -playlist http://playerservices.streamtheworld.com/pls/KDFCFMAAC.pls
The above works. The selected lines are from my "alarm clock". Perhaps you can use what I did as a guide to get your own system working.
scruss
Re: Cron scheduling to play music using mpg123 issue
Mon Aug 02, 2021 8:57 am
No, you don't need to use sudo. This should make it work:
00 07 * * * DISPLAY=:0.0 /usr/bin/mpg123 --shuffle /home/pi/Documents/Cron-task/music/*.mp3
For various reasons, sound playing is typically attached to where the display (X server) is running on Linux. The cron process doesn't know about any display settings for the system, so can't play sounds unless you tell it how.
(This is one of the old and confusing bits about ‘the Unix way’ that I wish would go away forever. How much sense does it make to have to do something about a display when you want sound? None!)
Pronouns: he/him
