cleverca22
Re: Pi4 reboot not reliable
Wed Apr 07, 2021 12:42 am
try using code tags instead of quote tags, it makes it easier to read
ganzgustav22
Wed Apr 07, 2021 8:57 am
Done.
Also opened an issue on Github:
https://github.com/raspberrypi/firmware/issues/1559
ganzgustav22
Mon Apr 12, 2021 1:30 pm
The issue occured on a different machine today (unfortunately this one didn't have serial logging connected). Firmware etc. on that one are still like in the first post (i.e. Raspberry Pi OS 2021-01-11 and the firmware/eeprom/vl805fw that comes with it)
This time it drew some weird pixels on the screen, mostly blue ones, but also some red ones in a seemingly random pattern
ganzgustav22
Tue Apr 13, 2021 10:23 am
And it got stuck again with the latest Raspberry Pi OS release. This time no serial log because there was no serialport connected (home office ...)
Linux raspberrypi 5.10.17-v7l+ #1403 SMP Mon Feb 22 11:33:35 GMT 2021 armv7l GNU/Linux
BOOTLOADER: up-to-date
CURRENT: Thu 18 Mar 08:54:11 UTC 2021 (1616057651)
LATEST: Thu 18 Mar 08:54:11 UTC 2021 (1616057651)
RELEASE: stable (/lib/firmware/raspberrypi/bootloader/stable)
Use raspi-config to change the release.
VL805_FW: Dedicated VL805 EEPROM
VL805: up-to-date
CURRENT: 000138a1
LATEST: 000138a1
ganzgustav22
Wed Jul 28, 2021 2:23 pm
Just tried it again with Raspberry Pi OS 2021-05-27 (and also ran rpi-eeprom-update -a to make sure it's using the firmware that comes with the release).
Issue still persists, it took about an hour of reboot loop until it got stuck again.
orignal_traveler
Re: Latest Pi 4 updates do not support GPU mem = 512
Fri Jul 30, 2021 9:06 pm
Just did apt update ( August 29, 2021) which updated seven items, including an eeprom update. An alert message was displayed stating that the system needed to be rebooted in order for the updates to take effect. When the reboot was done, the Pi went into a closed loop. A power cycle did not clear the loop. Boot is verbose without any apparent errors.
Raspberry PI 4B 8G
OS Buster 64bit
Dual HDMI Monitors
USB boot to SSD
Green light on seady except for an occasional blink
Disk activity light constantly flashing
Monitor screens blank except for blinking cursor in upper left corner
Removed the booting SSD and installed a previously working SD card, got the error "This board requires a later version of software"
Downloaded latest Raspberry PI OS 32bit (5-27-2021 full) image and installed on SD card. Booted card and did standard configuration and updates. SD card would boot and the dual monitors displayed the disktop without an issue.
Reset the GPU memory to the same as the Boot SSD (512) and the SD card did not boot properly. Reset GPU to 128 and the SD card booted properly. Reset GPU memory to 128 in config.txt on the Boot SSD and the Boot SSD booted and the monitors displayed the desktop without an issue. Enabled 64bit operation and the SSD booted and ran properly. Reset the GPU to 256 and the SSD booted and ran properly.
It is apparent that the latest updates to Raspberry PI OS and eeprom no longer support 512 as the GPU memory allocation. I have not attempted to run the graphics programs that I was able to previously so I don't know how they will work with the lower memory.
LTolledo
Fri Jul 30, 2021 9:43 pm
orignal_traveler wrote: by orignal_traveler » Sat Jul 31, 2021 6:06 am
something's not right here.... or maybe am just "dropped out of warp" to another timeframe....?
Some people be like:
ganzgustav22
Fri Aug 06, 2021 6:51 am
time_traveler wrote: by time_traveler » Sat Jul 31, 2021 6:06 am
See his nickname ;)
Seriously, I think what time_traveler, err, orignal_traveler described is a different issue, maybe related to changes on how gpu_mem is handled (I dimly remember reading somewhere, that more than 256gb gpu mem is not recommended/supported).
orignal_traveler
Sat Aug 07, 2021 5:30 pm
This is an update on my previous post about memory allocation issues after an update. I did an update yesterday that covered several Raspberry Pi OS internals. After that update, I again tried allocating 512M to GPU memory. The Pi 4 64b will now boot with a functioning, visible desktop. However, there are still a few issues with running downloaded videos even with Chrome media edition.
alphanumeric
Sat Aug 07, 2021 6:44 pm
I am a Linux Noob, and wondering why you
3. Write "reboot" into /etc/rc.local
tsthnh
Sun Aug 08, 2021 5:19 pm
tsthnh wrote:
Sat Feb 20, 2021 3:12 pm
I've recently noticed that rebooting does not seem to be reliable on the Pi4. Sometimes, after issueing the reboot command and after Linux has shutdown, it doesn't come back up and just sits there. After a while (not sure something around 20 seconds), the screen turns off and that's it. Only way to get it out of this is to power-cycle.
My RPI4 1GB Raspbian OS (32-bit) too. Sometimes, if RPI starts SWAP to SD-Card, i want to reboot and then no restart. Only Power-off.
For some time reboot works, now after reboot only Power-off (or screen off) again:
After 30 seconds I press the key ESC and I get the screen
[  OK  ] Stopped target Network (Pre).
         Stopping netfilter persistent configuration...
[  OK  ] Stopped netfilter persistent configuration.
[  **  ] A stop job is running for Make remote CUPS printers available locally (47s / 1min 30s)
After 1min 30s normal reboot.
That's ok for me. I just need reboot, no fast reboot.
