KamelKlutch
Ertm permission denied
Sat Jul 24, 2021 5:48 pm
I am trying to connect an Xbox one controller. I have followed all the guides, and I’m at the point where it connects but then disconnects immediately.
I tried running the following command:
sudo bash -c 'echo 1 > /sys/module/bluetooth/parameters/disable_ertm'
But I get a permission denied error. I am assuming that is why adding this line to the auto start does not seem to have a positive affect.
Does anyone know why I am getting the permission denied error?
cleverca22
Re: Ertm permission denied
Sat Jul 24, 2021 8:15 pm
because bluetooth is a module, you can also just set those options with modprobe.conf instead
an example from my system:
[clever@amd-nixos:~]$ cat /etc/modprobe.d/debian.conf
# These are the standard aliases and dependencies.
# This file does not need to be modified.
# prevent unusual drivers from appearing as the first sound device ###########
options snd-pcsp index=-2
options snd-usb-audio index=-2
so you probably want a file at /etc/modprobe.d/bluetooth.conf, with
options bluetooth disable_ertm=1
KamelKlutch
Sat Jul 24, 2021 8:49 pm
That worked to keep that option at Y.
Still can't get my XBox One controller working though.
Thanks for the help! Much appreciated.
