Pugpop
Active Cooling with the PiJuice
Sat Jul 24, 2021 2:09 am
I've been trying to find any information on cooling the Pi4 while using the PiJuice hat. It would seem that the hat would make the heating problem worse. Is there any official recommendation concerning this? I'm mounting the Pi on a din rail with a DINrPlate without a case.
aBUGSworstnightmare
Re: Active Cooling with the PiJuice
Sat Jul 24, 2021 5:16 am
viewtopic.php?f=45&t=316023&p=1891965#p1891965
The question in this thread is also down to cooling with a HAT connected. If you want to have active cooling you can use different solution like i.e. https://geekworm.com/collections/raspbe ... k-with-fan or https://www.berrybase.de/neu/armor-geh- ... arz?c=2389
