AnneRanch
SSH connection refused ?
Fri Jul 23, 2021 5:08 pm
I am trying to recover from lost IP (?)
I did
ifconfig
  • qe@qe-desktop:~$ ifconfig
    enp3s0: flags=4163<UP,BROADCAST,RUNNING,MULTICAST> mtu 1500
    inet 10.0.1.143 netmask 255.255.255.0 broadcast 10.0.1.255
    inet6 fe80::ac69:4602:623e:8c4f prefixlen 64 scopeid 0x20<link>
    ether d0:50:99:a4:fe:80 txqueuelen 1000 (Ethernet)
    RX packets 301811 bytes 317523806 (317.5 MB)
    RX errors 0 dropped 7 overruns 0 frame 0
    TX packets 210179 bytes 31495285 (31.4 MB)
    TX errors 0 dropped 0 overruns 0 carrier 0 collisions 0
    lo: flags=73<UP,LOOPBACK,RUNNING> mtu 65536
    inet 127.0.0.1 netmask 255.0.0.0
    inet6 ::1 prefixlen 128 scopeid 0x10<host>
    loop txqueuelen 1000 (Local Loopback)
    RX packets 1648 bytes 165370 (165.3 KB)
    RX errors 0 dropped 0 overruns 0 frame 0
    TX packets 1648 bytes 165370 (165.3 KB)
Assuming RPi is 10.0.1.143 (? not sure ) I did
  • qe@qe-desktop:~$ ssh rpi@10.0.1.143
    ssh: connect to host 10.0.1.143 port 22: Connection refused
then I did ping
  • PING 10.0.1.143 (10.0.1.143) 56(84) bytes of data.
    64 bytes from 10.0.1.143: icmp_seq=1 ttl=64 time=0.046 ms
    64 bytes from 10.0.1.143: icmp_seq=2 ttl=64 time=0.051 ms
    64 bytes from 10.0.1.143: icmp_seq=3 ttl=64 time=0.057 ms
    64 bytes from 10.0.1.143: icmp_seq=4 ttl=64 time=0.053 ms
    64 bytes from 10.0.1.143: icmp_seq=5 ttl=64 time=0.055 ms
    64 bytes from 10.0.1.143: icmp_seq=6 ttl=64 time=0.051 ms
    64 bytes from 10.0.1.143: icmp_seq=7 ttl=64 time=0.053 ms
    64 bytes from 10.0.1.143: icmp_seq=8 ttl=64 time=0.059 ms
    64 bytes from 10.0.1.143: icmp_seq=9 ttl=64 time=0.047 ms
    64 bytes from 10.0.1.143: icmp_seq=10 ttl=64 time=0.054 ms
    --- 10.0.1.143 ping statistics ---
    10 packets transmitted, 10 received, 0% packet loss, time 9200ms
    rtt min/avg/max/mdev = 0.046/0.052/0.059/0.003 ms
Am I barking at the wrong tree?
As far as I know , my RPi is SSh enabled , but I have not checked recently.
If I cannot get SSH to work I will have to
connect mouse , keyboard and monitor to RPi - not difficult but messy moving all that hardware from my PC.
Cheers
Re: SSH connection refused ?
Fri Jul 23, 2021 5:12 pm
I did
ifconfig
This is showing the IP address of the computer your are using. Not the Pi.
Can you connect to your Router/DHCP server and get a list of the addresses it has allocated? You might be able to find your Pi - if it is working - on there.
Unreadable squiggle
pasman1
Fri Jul 23, 2021 5:40 pm
can you install nmap ?
Pi4 RaspbOS 64+LXQT, linux 5.10.52-v8
B.Goode
Fri Jul 23, 2021 6:43 pm
