doodeet3
Pi 400 case
Wed Jul 21, 2021 6:21 pm
hey you know how there are cases for the pi 4, well is there a case for the 400 without a keyboard?
Re: Pi 400 case
Wed Jul 21, 2021 6:23 pm
Not in that form factor, but we make a case for the pi4 which has the same capabilities.
Working in the Application's Team.
Blanktopcoder
Re: Pi 400 case
Wed Jul 21, 2021 6:57 pm
Yes you can get a case for the pi 400! Go to PiHut website and there will be a large array of cases! :D
doodeet3
Re: Pi 400 case
Thu Jul 22, 2021 1:19 am
no like a case like the pi 4 has a case/box like the pi 400 would not have the keyboard but just the tech
W. H. Heydt
Re: Pi 400 case
Thu Jul 22, 2021 1:26 am
The keyboard and stiffener plate/heat sink is the tech the distinguishes the pi400 from the pi4, so that *is* the case.
ejolson
Re: Pi 400 case
Thu Jul 22, 2021 3:06 am
I think the Pi 400 would fit in a standard laptop bag, but there would be lots of extra room inside and it's not clear how well the power adapter would fit.
Imperf3kt
Contact: Twitter
Re: Pi 400 case
Thu Jul 22, 2021 4:07 am
The pi400 is also clocked higher by default so there is that minor difference as well as potentially having a more desirable form factor design (all ports on one edge is a major purchasing decision for some people)
55:55:44:44:4C
52:4C:52:42:41
HermannSW
Re: Pi 400 case
Thu Jul 22, 2021 4:50 am
You can easily open Pi400 case and disconnect keyboard cable.
I opened and added RTC to my Pi400:
viewtopic.php?f=140&t=309191&p=1849682& ... 0#p1849682
https://stamm-wilbrandt.de/2wheel_balancing_robot
https://stamm-wilbrandt.de/en#raspcatbot
https://github.com/Hermann-SW/raspiraw
https://stamm-wilbrandt.de/en/Raspberry_camera.html
W. H. Heydt
Re: Pi 400 case
Thu Jul 22, 2021 5:26 am
The higher default clock is because of that stiffener plate/heat sink.
aBUGSworstnightmare
Re: Pi 400 case
Thu Jul 22, 2021 5:57 am
A standard Pi4 4GB in an armour case (i.e. https://www.berrybase.de/neu/armor-geh- ... arz?c=2389) can be easily used at 2GHz.
And no, you can't buy the Pi400 mainboard and no, there is no case for it as well! If you want to have all connectors on one side get a CM4 + CM4IO + case https://www.berrybase.de/neu/metall-geh ... ter?c=2410
Add a passive heatsink if you want it to be quiet viewtopic.php?f=98&t=298810
Imperf3kt
Contact: Twitter
Re: Pi 400 case
Thu Jul 22, 2021 6:38 am
I thought it was partially because of the plate/Heatsink. The Pi400 received a C0 stepping revision that the pi4b did not get.
viewtopic.php?f=63&t=314313&p=1880810#p1880597
Has it already received that stepping now? There is no way to know as a consumer.
55:55:44:44:4C
52:4C:52:42:41
Re: Pi 400 case
Thu Jul 22, 2021 9:02 am
The C0 will eventually end up on the Pi4 as well. Might even be out there already on the CM4? We don't announce stuff like that as it should be a transparent change.
