electronicstoday
How to RE-ENABLE Google sync on "Chromium"
Thu Jun 24, 2021 12:54 am
How to RE-ENABLE Google's syncing of history, passwords, credit cards, logins etc, on Chromium, FOR NOW, after they so kindly decided to remove it for no sane reason (Google can be quite infuriating at times):
# Tested only on my Raspberry Pi 400, fully up to date; I am sure this method is platform agnostic, ergo should work on most *nix systems #
1:
sudo nano /etc/chromium-browser/customizations/00-rpi-vars
2:
Paste in the red parts AS IS, in that file (green parts are the existing content of that file - make a backup if needed):
CHROMIUM_FLAGS="${CHROMIUM_FLAGS} --force-renderer-accessibility --disable-quic --enable-tcp-fast-open --oauth2-client-id=77185425430.apps.googleusercontent.com --oauth2-client-secret=OTJgUOQcT7lO7GsGZq2G4IlT"
Et voila! It works! Tested on my Pi 400 as below:
PRETTY_NAME="Raspbian GNU/Linux 10 (buster)"
NAME="Raspbian GNU/Linux"
VERSION_ID="10"
VERSION="10 (buster)"
VERSION_CODENAME=buster
ID=raspbian
ID_LIKE=debian
Last edited by electronicstoday on Sun Jul 11, 2021 3:34 am, edited 1 time in total.
Re: How to RE-ENABLE Google sync on "Chromium"
Thu Jun 24, 2021 2:45 am
CHROMIUM_FLAGS="${CHROMIUM_FLAGS} --force-renderer-accessibility --disable-quic --enable-tcp-fast-open [
Looks like you have just published your google account client ID and password to the entire internet.
https://developers.google.com/identity/protocols/oauth2
Now we can all share your history, passwords, credit cards, logins etc.
Thanks.
electronicstoday
Thu Jun 24, 2021 3:21 am
Thanks.
Looks like you can’t, actually. You’d need to have my Google login. Let me ask - did you think to do a cursory, basic Google of the info I posted, before submitting your reply?
Look here: https://stackoverflow.com/questions/674 ... le-account
A quick Google of both those values shows they are seen in Chromium source code: https://chromium.googlesource.com/exper ... pi_keys.cc
Thu Jun 24, 2021 4:36 am
That is good to hear.
Still looks pretty scary to see anything called "secret" published.
No. I had only just woken up and read that before going to put the morning coffee on and have breakfast.
Let me ask - is it expected that one double check everything read here?
electronicstoday
Thu Jun 24, 2021 4:42 am
I shall hope that you meant your post in good will and in an attempt to protect me, so thank you - no harm done. :)
Imperf3kt
Contact: Twitter
Thu Jun 24, 2021 4:55 am
I'm still confused as to how Google had a feature removed from an unrelated browser in the first place.
55:55:44:44:4C
52:4C:52:42:41
electronicstoday
Thu Jun 24, 2021 5:01 am
Google and their "products", and their sheer arrogance, are a mystery to everyone. One day they will do something which backfires upon them, irreversibly... or they will be shut down for something they didn't see coming. Not one solitary tear, nor moment of sleep will be lost for their demise.
memjr
Thu Jun 24, 2021 5:25 am
They had previously added and their sync stuff to chromium's code. As others started to use chromium for their own browsers, i.e. Microsoft Edge, these other browsers also had the ability to sync like chrome. They decided that code should be restricted to Google's browsers only admit exposed apis only google was supposed to use. So they pulled the sync stuff back out from the chromium's code.
Not a huge deal. I have not tried on the pi yet, but if you really want the sync to work with your Google account. You can install chrome if you're running Debian amd-64/x64
electronicstoday
Thu Jun 24, 2021 7:28 am
It’s pretty obvious that’s the case. The very reason for this topic is that Raspberry Pi OS *cannot* run Chrome, and comes with Chromium, hence the workaround. I don’t think I’d have bothered going to this effort, had Chrome ARMHF been available.
LOL.
mahjongg
Thu Jun 24, 2021 12:14 pm
for what its worth, I removed the secret password from some posts, (but as they say the internet never forgets).
P.S. for what its worth, I CANNOT undelete a deleted text. Only the original poster knows what was once there and HE can put it back if he wants to.
cleverca22
Thu Jun 24, 2021 12:48 pm
the code for sync was in the base chromium
and the hosting for all of that data was on google servers
and now google is having to pay storage costs for microsoft edge sync!!
so they changed the rules, so that only the official chrome build, and low-usage user-created keys can do sync
craigevil
Thu Jun 24, 2021 3:22 pm
The actual steps to get Sync back in Chromium:
How to enable Chromium sync on Twister/RPiOS
1. Go to https://www.chromium.org/developers/how-tos/api-keys and follow the instructions to join the groups (https://groups.google.com/u/0/a/chromiu ... unts?pli=1 and https://groups.google.com/a/chromium.or ... romium-dev) and such in order to enable all APIs with "chrome" in their name, and to generate a:
- API key
- OAuth client id
- OAuth client secret
2. nano ~/.profile, then paste in the following:
env GOOGLE_API_KEY="API_key"
env GOOGLE_DEFAULT_CLIENT_ID="client_id"
env GOOGLE_DEFAULT_CLIENT_SECRET="client_secret"
Replace all the fields with your credentials you generated.
Run ctrl+x, then press y and enter to exit nano.
3. Just logout, then log back into your account. Run Chromium and sign in to enable sync!
Raspberry PI 400 Raspberry Pi OS (Unstable) Kernel: 5.10.17-v8+ aarch64 DE: MATE Ram 4GB
Debian - "If you can't apt install something, it isn't useful or doesn't exist"
electronicstoday
Thu Jun 24, 2021 6:38 pm
It's "secret" by name, it's not actually a secret. The whole point of the topic pivots around that data, so it would be remiss of you to leave it obscured; were it actually a secret, I don't think it would be wide open and visible in Google source. This speaks of ignorance towards how API keys work.
Last edited by electronicstoday on Sun Jul 11, 2021 3:31 am, edited 1 time in total.
electronicstoday
Thu Jun 24, 2021 6:45 pm
- API key
- OAuth client id
CaptainMidnight
Fri Jun 25, 2021 3:55 am
electronicstoday and craigevil thank you my friends for providing this information, I haven't tried the 2nd method yet due to time constraints, but the 1st certainly works.
I know what I like and I like what I see ;)
"Never get out of the boat." Absolutely goddamn right!
Unless you were goin' all the way...
