emmet62h
Using RSP-Zero WH with WPA2-PSK
Wed Jun 16, 2021 1:44 am
Hi all,
I am haven't connected to wifi yet with this board! I am having a pretty rough time. Here is my WPA_Supplicant code below. My wifi is 2.4Ghz with WPA-Personal wifi (WPA2-PSK should work). Please help.
File:
country=US
update_config=1
network={
ssid="Damon's Wi-Fi Network"
#ssid="ComputerCenter"
scan_ssid=1
psk="@@123"
proto=RSN
key_mgmt=WPA-PSK
pairwise=CCMP
group=TKIP
auth_alg=OPEN
#key_mgmt=NONE
drgeoff
Re: Using RSP-Zero WH with WPA2-PSK
Wed Jun 16, 2021 2:25 pm
Your wpa_suplicant.conf file is not in your post.
Quis custodiet ipsos custodes?
emmet62h
Wed Jun 16, 2021 8:02 pm
Thank you for letting me know. I put in text rather than attaching the file.
jbudd
Wed Jun 16, 2021 8:12 pm
For WPA2-PSK you should only need
country=US
update_config=1
network={
	psk="@@123"
And if you are unfortunate enough to be dealing wih a hidden SSID add scan_ssid=1
Get rid of all those other lines including the comments and try again.
Make sure that the quotes have not been "enhanced" by a word processor.
Edit - I don't think it's a very good idea to have an apostrophe in your SSID. Maybe try changing that too.
emmet62h
Thu Jun 17, 2021 12:03 am
Thank you Jbudd for your quick response. I have tried that and it doesn't seem to work.
jbudd
Thu Jun 17, 2021 12:14 am
If you use sudo raspi-config , System Options, Wireless LAN, does it let you enter an SSID and password without an error?
Does it create a new network={} stanza in wpa_supplicant.conf?
NB I think you must enter at least 8 characters for the password.
I wonder if that's a limitation of raspi-config or a requirement of wpa_supplicant.
Edit - following the suggestion from bls below, I tried
pi@BlackPi:~ $ wpa_passphrase "Damon's Wi-Fi Network" <<< "@@123"
# reading passphrase from stdin
Passphrase must be 8..63 characters
So the example password from your original post is illegal. But I expect it's not your real password!
bls
Thu Jun 17, 2021 12:20 am
I couldn't find a definitive list of "special characters" to determine if a single quote is a special character, but in case it is, you could look at using a passphrase instead:
bash$ wpa_passphrase SSID <<< "WiFiPassword"
network={
        ssid="SSID"
        #psk="WiFiPassword"
        psk=c9c3405ecf541762bdeadbeef68c05cb106d69112f604c9b2199effacefffeed
You can then paste the appropriate lines (e.g., the psk= line) into your wpa_supplicant.conf. If it works, then you'll know tha a single quote is a "special" character. Please let us know!
Pi tools:
Quickly and easily build customized-just-for-you SSDs/SD Cards: https://github.com/gitbls/sdm
Easily run and manage your network's DHCP/DNS servers on a Pi: https://github.com/gitbls/ndm
Easy and secure strongSwan VPN installer/manager: https://github.com/gitbls/pistrong
Lightweight Virtual VNC Config: https://github.com/gitbls/RPiVNCHowTo
