carsten_h
Chromium no login (sync) possible
Mon May 17, 2021 11:45 am
Hello!
I installed Chromium 88 new and tried to login to sync bookmarks and so on. But it is not working.
I first tried to login to gmail, which is possible and my sign on the webpage is visible. I did this because all the other threads told that I first have to login to gmail and then to sync, but this doesn't help here.
But when I try to login for sync afterwards, the singn for login is not updated and I see no error message or something like that.
Bildschirmfoto 2021-05-17 um 13.34.58.png (23.47 KiB) Viewed 454 times
GMail is working fine without any problem, but sync login is not possible.
I totally deleted Chromium 88 with all cache and so on and installed Chromium 90 but nothing is changed. The sync login is not possible.
Is there someone who can help me? What can I do?
I am running the newest version of Raspberry Pi OS Buster with all updates and now Chromium 90.0.4430.93-1 deb10u1.
Re: Chromium no login (sync) possible
Mon May 17, 2021 11:56 am
Hello!
Google have removed many "features" from chromium browser
https://www.omgubuntu.co.uk/2021/01/chr ... i-removed/
This has already been discussed in previous posts ;)
My other Linux machines: ChromeBox
https://www.aliexpress.com/item/32966393971.html
& Stone Desktop Intel CoreDuo circa 2010
carsten_h
Mon May 17, 2021 2:40 pm
I always saw at the end that it is still working. But OK if Google has killed that, they killed it.
Thank you for the answer!
craigevil
Mon May 17, 2021 4:01 pm
Use Vivaldi.
I copied my Chromium profile over Vivaldi, then setup the sync feature in it. Now I have a browser that syncs on all my devices.
I had already imported my Chromium bookmarks into Firefox.
And since i use Bitwarden my passwords are available on which ever browser I use.
I completely removed Chromium, screw Google.
Raspberry PI 400 Raspberry Pi OS (Unstable) Kernel: 5.10.42-v8+ aarch64 DE: MATE Ram 4GB
Debian - "If you can't apt install something, it isn't useful or doesn't exist"
carsten_h
Mon May 17, 2021 9:54 pm
Use Vivaldi
Is there a version of Vivaldi for Raspberry Pi OS?
I am already using it on Windows an my Mac. So this would be great.
craigevil
Mon May 17, 2021 10:55 pm
Use Vivaldi
Yes:
arm32 : https://downloads.vivaldi.com/stable/vi ... _armhf.deb
arm64: https://downloads.vivaldi.com/stable/vi ... _arm64.deb
Both add the Vivaldi repo, but only the arm32 repo works. so if you are running Rasp pi OS arm64 comment the repo.
You can also download the Snapshot version.
https://vivaldi.com/blog/desktop/on-to- ... ot-2289-3/
