dan-k
MOST RELIABLE SD CARD !!!!
Mon May 10, 2021 11:04 pm
Hey Everyone?
I am using rasp pi for my IoT fleet,
I get a lot "kernel panic" error.
I would be happy to know what is the cause for that ??
Moreover, I would love to hear whIch SD cards are absolutely top-of-the-line most reliable, and robust.
Thx in advance
RaspbianUser1
Re: MOST RELIABLE SD CARD !!!!
Tue May 11, 2021 12:04 am
Endurance sandisk
Running with a Raspberry Pi 4B 4GB with Raspberry Pi OS with MATE Desktop
Why not overclock, push some more performance out of your computer!
Think before you delete something a stranger on the internet told you to.
Imperf3kt
Contact: Twitter
Tue May 11, 2021 3:25 am
The current top recommended micro SD cards for use with a raspberry Pi are SanDisk A1 rated cards, followed closely by any other brand with specs in the same class.
55:55:44:44:4C
52:4C:52:42:41
Rose tinted glasses are difficult to see through.
Gavinmc42
Tue May 11, 2021 6:14 am
It is not just the card, it is the OS.
Not sure what OS you are using?
I choose PiCore and Ultibo for my IoT devices.
That way I can control the erase/write cycling on those.
Old SLC, single Layer Cells have more erase/write cycles.
My longest lasting cards are old SLC 128MB SD cards.
You need to minimize erase/write cycling.
The 16GB A1 Sandisk are my preferred consumer cards for Linux use.
It would be nice if someone made FRAM or similar uSDs, 128MB is all I need.
Guessing IoT guys would use industrial cards?
https://www.delkin.com/products/industrial-microsd/
I'm dancing on Rainbows.
ganzgustav22
Tue May 11, 2021 8:10 am
Search the web for "industrial grade microsd card".
In general, even the best sdcards will wear out and fail eventually when you're writing to them a lot. Run these systems with read-only filesystems if you want them to be reliable.
Tue May 11, 2021 9:14 am
Sandisk have come out tops in our testing. We've not had a single failure due to random power drops on Sandisk.
Working in the Application's Team.
jahboater
Tue May 11, 2021 9:46 am
+1
I have Sandisk A1 class cards in all my Pi's for years and simply never see failures or corruption.
They are fast enough that I don't feel an urgent need to use an SSD (and 8GB Pi4's have plenty of space for a huge disk cache).
BossCoding
Fri May 14, 2021 1:38 am
probably sandisk 68GB
gordon77
Fri May 14, 2021 6:31 am
68GB ?
