gogoer
Map usb adapters to /dev ports
Fri May 07, 2021 7:29 am
Hello.
I have RPi 3 B and three uart adapters. Adapters are the same.
When i install them, i can see them in /dev for examle: adapter1 - /dev/ttyUSB0, adapter2 - /dev/ttyUSB1, adapter3 - /dev/ttyUSB2.
But after system reboot the can change their location: adapter1 - /dev/ttyUSB1, adapter2 - /dev/ttyUSB2, adapter3 - /dev/ttyUSB0.
lsusb
Bus 001 Device 006: ID 10c4:ea60 Cygnal Integrated Products, Inc. CP2102/CP2109 UART Bridge Controller [CP210x family]
Bus 001 Device 005: ID 10c4:ea60 Cygnal Integrated Products, Inc. CP2102/CP2109 UART Bridge Controller [CP210x family]
Bus 001 Device 004: ID 10c4:ea60 Cygnal Integrated Products, Inc. CP2102/CP2109 UART Bridge Controller [CP210x family]
Is there any way to map adapter to ttyUSB port to prevent migration?
Doug_
Re: Map usb adapters to /dev ports
Mon May 10, 2021 1:45 am
When all the interfaces are plugged in you will find sym links to the port listed in the /dev/serial/by-id/ and /dev/serial/by-path/, these sym links can be used in place of the /dev/ttyUSB0 or similar port reference.
So at the command prompt enter the following to reveal the links:
ls -l /dev/serial/by-path/
or
ls -l /dev/serial/by-id/
Skraps
Mon May 10, 2021 7:24 am
Ive a new zero user right. Then theres a domain format daemon also. So you could map and static the mapping thru avahi. < thats a real thing. Uhh
Im not sure what else to tell ya. Ive never had that problem. Other than procedence as it registers by electrical concurrent or chronological ordering by power thruput.
gogoer
Tue May 11, 2021 11:27 pm
Thank you for help!
But in my case i have identical devices, and i cannot detect them by idProduct or idVendor.
if i understand there is no way to detect them exatly, it is better to use different adapters.
epoch1970
Tue May 11, 2021 11:51 pm
There is the option of detecting the path, i.e. which USB port is connected. That doesn’t change, so you could have something like /dev/usb/top/left/dev0, /dev/usb/bottom/left/dev0 etc.
Use udev rules to create the paths.
