kcajminer2312
[SOLVED] Raspberry pi Zero Crashes
Sun May 09, 2021 11:45 am
my raspberry pi zero keeps crashing while running samba
Last edited by kcajminer2312 on Sat May 15, 2021 10:07 am, edited 1 time in total.
thagrol
Re: Raspberry pi Zero Crashes
Sun May 09, 2021 12:07 pm
No one will be able to offer help without a lot more information.
I'm a volunteer. Take me for granted or abuse my support and I will walk away
All advice given is based on my experience. it worked for me, it may not work for you.
Need help? https://github.com/thagrol/Guides
kcajminer2312
Sun May 09, 2021 12:08 pm
well what information do you need
rpdom
Sun May 09, 2021 12:19 pm
All of it?
What OS have you installed? Raspberry Pi OS, or another? Lite, Standard, Full?
What have you added?
What chages have you made?
How have you configured Samba?
We cannot read your mind.
Unreadable squiggle
thagrol
Sun May 09, 2021 12:38 pm
To add to that:
What network hardware you're using with the zero (or is it actually a zeroW?)
The output from
testparm -s
What error message, if any, is present in /var/log/syslog.
What you have tried yourself to resolve it.
Whether you've connected a monitor, and if so what error message(s) were displayed on it. If you haven't done this, come back when you have.
kcajminer2312
Sun May 09, 2021 1:29 pm
All of it?
Rasperry pi os standard
only samba/smbd
nothing
file server
its just a normal raspberry pi os install with samba installed
energyi
Sun May 09, 2021 5:55 pm
Use a high quality power supply and see if the problems go away.
energyi
kcajminer2312
Sun May 09, 2021 6:54 pm
I have used an official raspberry pi 3 power supply
kcajminer2312
Sun May 09, 2021 9:56 pm
Also this is acting as a backup server so this needs fixing quickly
thagrol
Sun May 09, 2021 10:00 pm
Demands for a quick fix usually don't result in one unless you're demanding it from a paid support service.
And you still haven't provied anywhere near enough and specific enough information for anyone to help.
Unsubscribing from this thread now.
kcajminer2312
Sun May 09, 2021 10:02 pm
I come on here for help and you should understand why it needs doing quickly if its for backups.
i have about half a backup of my system
and what other information can i say.
its headless, I don't know what's crashing it
And I was never demanding it
thagrol
Sun May 09, 2021 10:26 pm
Oops. Forgot to unsubscribe.
Whether it's for backups or not I'm not a mind reader. Also, I and no one else on here is paid or required to help you. We're all volunteers.
That's unfortunate but not something I or ayone else can do anything about. It's also not a reason you should be expecting paid levels of support.
Start here viewtopic.php?p=1862909#p1862686 and here viewtopic.php?p=1862909#p1862666 (Your answer of nothing to "what have you added" is clearly not true. A zero has no network interface so there is little point in running samba on it). then add
  • The output from
    uname -a
  • The output from
    cat /etc/os-release
  • As already requested, the output from
    testparm -s
  • Also as already requested details of any errors perent in /var/log/syslog.
Neither do we. We're not psychic, we don't have access to your Pi, and the information you've provided is vague at best.
Maybe not in those words but that's how your post came across. You are certainly putting pressure on us with "this needs fixing quickly". If you want profession levels of support you need to pay for it.
Really unsubscribing now.
ejolson
Mon May 10, 2021 3:26 am
It's an interesting idea to use a Pi Zero as a backup server. Have you connected a USB hub? Are you storing the backup on an SD card or a USB attached disk. I had good luck with a USB Ethernet adapter. Which network adapter are you using?
kcajminer2312
Mon May 10, 2021 9:50 am
Nothing to do with it crashing but it’s an external hard drive and my usb WiFi adapter is the one by the pi hut https://thepihut.com/products/usb-wifi- ... spberry-pi
Mon May 10, 2021 9:56 am
How are you attaching USB Peripherals to the single USB Port ?
I would expect that you are overwhelming the USB I/O and the Single Core ARM CPU Zero is running out of resources..
Use your RPi 4B and see if that makes a difference ;)
Last edited by fruitoftheloom on Mon May 10, 2021 9:59 am, edited 1 time in total.
My other Linux machines: ChromeBox
https://www.aliexpress.com/item/32966393971.html
& Stone Desktop Intel CoreDuo circa 2010
kcajminer2312
Mon May 10, 2021 9:58 am
A usb hub
how else would I do it
kcajminer2312
Mon May 10, 2021 10:02 am
I would but my ssd connect draws about 1 amp and my powered USB hub back feeds power
Mon May 10, 2021 10:15 am
The total USB power (not per port) on a 4B is 1200mA using the Official PSU:
https://www.raspberrypi.org/documentati ... ower-specs
kcajminer2312
Mon May 10, 2021 10:16 am
I know that's why I said It my HDD in my pi zero would make that about 2 amps so it wouldn't work
Mon May 10, 2021 10:43 am
I do not understand your replies, I give up :?
kcajminer2312
Mon May 10, 2021 10:44 am
I said if i use my 4B, I have a usb ssd connected so I will go over the power limit
1amp(SSD) + 1amp(HDD) = 2 amps total
ejolson
Mon May 10, 2021 2:32 pm
My suggestion is to try clocking the zero at 700 MHz using the config.txt file to see if that improves the stability.
thagrol
Mon May 10, 2021 5:18 pm
Mine is that you (OP) provide the infomration that's been asked for several times now or buy a self powered USB hub (or self powered drive enclosures) and use the 4B.
kcajminer2312
Mon May 10, 2021 5:19 pm
I have gave what you have asked for
If you must know /var/log/syslog
its too long to post
thagrol
Mon May 10, 2021 5:50 pm
No. You haven't.
You have yet to post any of the following:
  • The output from
    testparm -s
  • What error message, if any, is present in /var/log/syslog (I did not ask for all of it)
  • Whether you've connected a monitor, and if so what error message(s) were displayed on it.
  • The output from
    uname -a
  • The output from
    cat /etc/os-release
  • What you have tried yourself to resolve it. Though I'm guessing the answer to that is ask for help on the forum
But don't bother. My patience has finally expired.
