aleborjas
pi4 crash out
Thu May 06, 2021 4:20 pm
Hi guys!!!
I have a big problem, I have 3 raspi 4 new ones, they don't grab the image from the sd of another one that I have running, then I installed everything from scratch on a new sd and all 3 burst, in the log I can see this but I don't know how to correct it.
May  6 11:04:06 raspberrypi kernel: [ 6523.537349] ------------[ cut here ]------------
May  6 11:04:06 raspberrypi kernel: [ 6523.537379] WARNING: CPU: 3 PID: 551 at drivers/firmware/raspberrypi.c:64 rpi_firmware_transaction+0xec/0x128
May  6 11:04:06 raspberrypi kernel: [ 6523.537389] Firmware transaction timeout
May  6 11:04:06 raspberrypi kernel: [ 6523.537399] Modules linked in: rfcomm cmac bnep hci_uart btbcm bluetooth ecdh_generic ecc fuse 8021q garp stp llc usblp ch341 usbserial rpivid_mem v3d brcmfmac gpu_sched brcmutil sha256_generic joydev cfg80211 rfkill raspberrypi_hwmon vc4 cec drm_kms_helper drm snd_bcm2835(C) bcm2835_codec(C) drm_panel_orientation_quirks bcm2835_v4l2(C) bcm2835_isp(C) hid_multitouch bcm2835_mmal_vchiq(C) v4l2_mem2mem snd_soc_core vc_sm_cma(C) videobuf2_dma_contig snd_compress snd_pcm_dmaengine syscopyarea sysfillrect sysimgblt fb_sys_fops backlight uio_pdrv_genirq nvmem_rmem uio uvcvideo snd_usb_audio videobuf2_vmalloc videobuf2_memops snd_hwdep videobuf2_v4l2 snd_usbmidi_lib videobuf2_common snd_rawmidi snd_seq_device snd_pcm videodev snd_timer mc snd i2c_dev ip_tables x_tables ipv6
May  6 11:04:06 raspberrypi kernel: [ 6523.538063] CPU: 3 PID: 551 Comm: Xorg Tainted: G         C        5.10.17-v7l+ #1403
May  6 11:04:06 raspberrypi kernel: [ 6523.538069] Hardware name: BCM2711
May  6 11:04:06 raspberrypi kernel: [ 6523.538077] Backtrace:
May  6 11:04:06 raspberrypi kernel: [ 6523.538099] [<c0b63050>] (dump_backtrace) from [<c0b633e4>] (show_stack+0x20/0x24)
May  6 11:04:06 raspberrypi kernel: [ 6523.538109]  r7:ffffffff r6:00000000 r5:60000013 r4:c12e69fc
May  6 11:04:06 raspberrypi kernel: [ 6523.538122] [<c0b633c4>] (show_stack) from [<c0b67774>] (dump_stack+0xcc/0xf8)
May  6 11:04:06 raspberrypi kernel: [ 6523.538135] [<c0b676a8>] (dump_stack) from [<c0220bac>] (__warn+0xfc/0x114)
May  6 11:04:06 raspberrypi kernel: [ 6523.538145]  r10:dec09008 r9:00000009 r8:c099d5b8 r7:00000040 r6:00000009 r5:c099d5b8
May  6 11:04:06 raspberrypi kernel: [ 6523.538152]  r4:c0e9abc8 r3:c1205094
May  6 11:04:06 raspberrypi kernel: [ 6523.538164] [<c0220ab0>] (__warn) from [<c0b63b88>] (warn_slowpath_fmt+0xa4/0xd8)
May  6 11:04:06 raspberrypi kernel: [ 6523.538173]  r7:00000040 r6:c0e9abc8 r5:c1205048 r4:c0e9abe8
May  6 11:04:06 raspberrypi kernel: [ 6523.538186] [<c0b63ae8>] (warn_slowpath_fmt) from [<c099d5b8>] (rpi_firmware_transaction+0xec/0x128)
May  6 11:04:06 raspberrypi kernel: [ 6523.538195]  r9:c1a94540 r8:00000018 r7:00000000 r6:ffffff92 r5:c1a94540 r4:c1205048
May  6 11:04:06 raspberrypi kernel: [ 6523.538208] [<c099d4cc>] (rpi_firmware_transaction) from [<c099d6b0>] (rpi_firmware_property_list+0xbc/0x170)
May  6 11:04:06 raspberrypi kernel: [ 6523.538217]  r7:c1205048 r6:dec09000 r5:00001000 r4:dec09024
May  6 11:04:06 raspberrypi kernel: [ 6523.538228] [<c099d5f4>] (rpi_firmware_property_list) from [<c099d7d4>] (rpi_firmware_property+0x70/0x118)
May  6 11:04:06 raspberrypi kernel: [ 6523.538238]  r10:c575ae4c r9:00038002 r8:00000018 r7:c1a94540 r6:c3c19c60 r5:0000000c
May  6 11:04:06 raspberrypi kernel: [ 6523.538244]  r4:c575ae40
May  6 11:04:06 raspberrypi kernel: [ 6523.538257] [<c099d764>] (rpi_firmware_property) from [<c07e4e54>] (raspberrypi_clock_property+0x54/0x7c)
May  6 11:04:06 raspberrypi kernel: [ 6523.538266]  r10:c398bc00 r9:0ee6b280 r8:1dcd6500 r7:c2093040 r6:00000000 r5:c3c19c88
May  6 11:04:06 raspberrypi kernel: [ 6523.538273]  r4:c1205048 r3:0000000c
May  6 11:04:06 raspberrypi kernel: [ 6523.538284] [<c07e4e00>] (raspberrypi_clock_property) from [<c07e4fb0>] (raspberrypi_fw_set_rate+0x4c/0xb8)
May  6 11:04:06 raspberrypi kernel: [ 6523.538291]  r5:c20934c0 r4:c1205048
May  6 11:04:06 raspberrypi kernel: [ 6523.538302] [<c07e4f64>] (raspberrypi_fw_set_rate) from [<c07dd348>] (clk_change_rate+0xf4/0x4ac)
May  6 11:04:06 raspberrypi kernel: [ 6523.538310]  r7:00000000 r6:00000000 r5:00000000 r4:c1b74a80
May  6 11:04:06 raspberrypi kernel: [ 6523.538321] [<c07dd254>] (clk_change_rate) from [<c07dd87c>] (clk_core_set_rate_nolock+0x17c/0x1a4)
May  6 11:04:06 raspberrypi kernel: [ 6523.538330]  r10:c398bc00 r9:00000000 r8:c1b74a80 r7:1dcd6500 r6:00000000 r5:c1205048
May  6 11:04:06 raspberrypi kernel: [ 6523.538337]  r4:c1b74a80
May  6 11:04:06 raspberrypi kernel: [ 6523.538348] [<c07dd700>] (clk_core_set_rate_nolock) from [<c07dd8e4>] (clk_set_rate+0x40/0x98)
May  6 11:04:06 raspberrypi kernel: [ 6523.538356]  r8:c56fad10 r7:c2d13000 r6:00000000 r5:1dcd6500 r4:c330da80
May  6 11:04:06 raspberrypi kernel: [ 6523.538389] [<c07dd8a4>] (clk_set_rate) from [<bf37ad58>] (v3d_clock_up_get+0x64/0xac [v3d])
May  6 11:04:06 raspberrypi kernel: [ 6523.538396]  r5:c2d133e8 r4:c2d13000
May  6 11:04:06 raspberrypi kernel: [ 6523.538435] [<bf37acf4>] (v3d_clock_up_get [v3d]) from [<bf37ae6c>] (v3d_job_init+0xcc/0xdc [v3d])
May  6 11:04:06 raspberrypi kernel: [ 6523.538442]  r5:c1205048 r4:c56facc0
May  6 11:04:06 raspberrypi kernel: [ 6523.538479] [<bf37ada0>] (v3d_job_init [v3d]) from [<bf37be68>] (v3d_submit_cl_ioctl+0xa4/0x63c [v3d])
May  6 11:04:06 raspberrypi kernel: [ 6523.538488]  r9:c0eb13f8 r8:c2d13000 r7:c2fe0200 r6:c56facc0 r5:c1205048 r4:c3c19e64
May  6 11:04:06 raspberrypi kernel: [ 6523.538636] [<bf37bdc4>] (v3d_submit_cl_ioctl [v3d]) from [<bf2e146c>] (drm_ioctl_kernel+0xb8/0xfc [drm])
May  6 11:04:06 raspberrypi kernel: [ 6523.538646]  r10:c3c19e64 r9:bf37bdc4 r8:00000021 r7:00000000 r6:c2fe0200 r5:c2d13000
May  6 11:04:06 raspberrypi kernel: [ 6523.538652]  r4:c1205048
May  6 11:04:06 raspberrypi kernel: [ 6523.538904] [<bf2e13b4>] (drm_ioctl_kernel [drm]) from [<bf2e1694>] (drm_ioctl+0x1e4/0x3a8 [drm])
May  6 11:04:06 raspberrypi kernel: [ 6523.538913]  r10:00000038 r9:c3c19e64 r8:c2fe0200 r7:00000040 r6:bf37bdc4 r5:c1205048
May  6 11:04:06 raspberrypi kernel: [ 6523.538920]  r4:bf382398
May  6 11:04:06 raspberrypi kernel: [ 6523.539051] [<bf2e14b0>] (drm_ioctl [drm]) from [<c045178c>] (sys_ioctl+0x1d4/0x8ec)
May  6 11:04:06 raspberrypi kernel: [ 6523.539060]  r10:0000000e r9:c3c18000 r8:00000000 r7:c2ef2300 r6:c2ef2301 r5:c1205048
May  6 11:04:06 raspberrypi kernel: [ 6523.539067]  r4:c0386440
May  6 11:04:06 raspberrypi kernel: [ 6523.539079] [<c04515b8>] (sys_ioctl) from [<c0200040>] (ret_fast_syscall+0x0/0x28)
May  6 11:04:06 raspberrypi kernel: [ 6523.539094] Exception stack(0xc3c19fa8 to 0xc3c19ff0)
May  6 11:04:06 raspberrypi kernel: [ 6523.539110] 9fa0:                   0116a660 0116a6a8 0000000e c0386440 0116a6a8 b60331cc
May  6 11:04:06 raspberrypi kernel: [ 6523.539129] 9fc0: 0116a660 0116a6a8 c0386440 00000036 b5e1c000 becd9c18 0021b9a0 00213eb0
May  6 11:04:06 raspberrypi kernel: [ 6523.539137] 9fe0: b6d4508c becd9b0c b6d2b88c b69b751c
May  6 11:04:06 raspberrypi kernel: [ 6523.539147]  r10:00000036 r9:c3c18000 r8:c0200204 r7:00000036 r6:c0386440 r5:0116a6a8
May  6 11:04:06 raspberrypi kernel: [ 6523.539153]  r4:0116a660
May  6 11:04:06 raspberrypi kernel: [ 6523.539162] ---[ end trace eb22094d7193b084 ]---
Thank you very much in advance for the help !!!!
terribleted
Re: pi4 crash out
Thu May 06, 2021 7:28 pm
must be a problem with making the SD Card.
to COPY a running system:
- Get a microSD to USB adapter.
- put the new SD card in it, plug it into one of the USB Ports on the running PI
- use the "SD Card Copier" (under accessories)
copy FROM (the mmcblk0 or something like that)
copy TO: the usb connected card, ususally sdasomething.
i do it all the time, works fine.
OR to install from scratch:
on another computer: (PC, MAC, or Linux)
- install "raspberry pi imager" from HERE: https://www.raspberrypi.org/software/
- download the PI OS from HERE: https://www.raspberrypi.org/software/operating-systems/
use the imager to write to the new card (i assume in a USB adapter)
it will go thru the first time setup the first time it boots.
i had a Trash-80 model 1 (circa 1980). upgrading from 4k to 16k of RAM, i thought "i'll never use this much RAM".
Now i have a computer with a million times that much memory. And i keep running out of it.
Not the computer....ME.
