cap_cap
Can't run VPN on Pi4
Tue May 04, 2021 1:51 am
Hellow,
I'm newbie and might not found the answer on the forum, apologies in advance if this was the case.
VPN provider is PIA
Fresh downloaded the configuration files. Here's the log:
pi@raspberrypi:~/Desktop/OpenVPN $ sudo openvpn austria.ovpn
Mon May 3 18:28:40 2021 OpenVPN 2.4.7 arm-unknown-linux-gnueabihf [SSL (OpenSSL)] [LZO] [LZ4] [EPOLL] [PKCS11] [MH/PKTINFO] [AEAD] built on Feb 20 2019
Mon May 3 18:28:40 2021 library versions: OpenSSL 1.1.1d 10 Sep 2019, LZO 2.10
Enter Auth Username: *********
Enter Auth Password: *********
Mon May 3 18:28:55 2021 TCP/UDP: Preserving recently used remote address: [AF_INET]156.146.60.72:501
Mon May 3 18:28:55 2021 Attempting to establish TCP connection with [AF_INET]156.146.60.72:501 [nonblock]
Mon May 3 18:28:56 2021 TCP connection established with [AF_INET]156.146.60.72:501
Mon May 3 18:28:56 2021 TCP_CLIENT link local: (not bound)
Mon May 3 18:28:56 2021 TCP_CLIENT link remote: [AF_INET]156.146.60.72:501
Mon May 3 18:28:57 2021 WARNING: this configuration may cache passwords in memory -- use the auth-nocache option to prevent this
Mon May 3 18:28:58 2021 [vienna403] Peer Connection Initiated with [AF_INET]156.146.60.72:501
Mon May 3 18:28:59 2021 OpenVPN ROUTE6: OpenVPN needs a gateway parameter for a --route-ipv6 option and no default was specified by either --route-ipv6-gateway or --ifconfig-ipv6 options
Mon May 3 18:28:59 2021 OpenVPN ROUTE: failed to parse/resolve route for host/network: 2000::/3
Mon May 3 18:28:59 2021 ERROR: Cannot open TUN/TAP dev /dev/net/tun: No such device (errno=19)
Mon May 3 18:28:59 2021 Exiting due to fatal error
Darthux
Re: Can't run VPN on Pi4
Wed May 05, 2021 1:37 am
its been about a year since I last used open vpn on a Pi, but I believe you have to use the --config option to connect to your saved file.
sudo openvpn --config austria.ovpn
Raspberry Pi Zero W: 2021 time lapse
Raspberry Pi Zero W: useless box in progress
Raspberry Pi 2B: Cellular environmental sensor
Raspberry Pi 3B: kodi
Raspberry Pi 3B+ : SmartMirror
Raspberry Pi 4 4G: idle
Raspberry Pi 400: develop and test
Wed May 05, 2021 9:39 am
Since you're paying real green dollars for your PIA service. Ask at https://www.privateinternetaccess.com/helpdesk/ that's one of the things you're paying for.
neilgl
Wed May 05, 2021 10:11 am
As far as I can see on their not very clear website, their Linux client does not support Raspberry Pi OS, it has “64bit only” and “ Requires Ubuntu 18.04+, Mint 19+, Arch, Debian” but never mind…
thatchunkylad198966
Thu May 06, 2021 1:15 pm
You can download just the .ovpn and connect that way. you do NOT need the client.
Source; have used PIA.
neilgl
Thu May 06, 2021 5:08 pm
Yes so he needs to ask the (paid for) support guys at PIA why it’s not connecting…
