Odyknuck
Keyboard compatibility
Sun Apr 18, 2021 12:01 pm
I have read on here that wireless keyboard/mouse with number pads do not work with the Pi4. Is this issue with all manufactures or a select few?
pidd
Re: Keyboard compatibility
Sun Apr 18, 2021 1:07 pm
Numeric keypads make no difference.
Dongle or bluetooth? Some dongles won't work close to the Pi so you put them on a USB extension lead and they work excellently.
Odyknuck
Sun Apr 18, 2021 9:33 pm
It would be a single Dongle for both Keyboard and mouse.
billsmithsmithbill22
Sun Apr 18, 2021 10:49 pm
I have tried many different keyboards with Pi's, and they have all worked fine. That being said, there are a few rare exceptions. It's likely as long as it is a major brand, your keyboard will work. Here are the ones tested to work with the pi:
https://elinux.org/RPi_USB_Keyboards
If it isn't on the list, or said elsewhere to be compatible, you run the risk of it not working, but you will likely be fine as long as it's a normal keyboard.
Note:
I'm typing this on a Logitech mouse+keyboard wireless combo with one dongle.
Good Luck!
drgeoff
Sun Apr 18, 2021 11:35 pm
Please provide a link to where you have read that.
Quis custodiet ipsos custodes?
Odyknuck
Tue Apr 20, 2021 1:29 am
Here is a link to a thread on this forum:
viewtopic.php?p=345907
BTW I received my Pi4 , wireless keyboard and mouse today and they are working fine. I did need to slow the mouse down as it was way too sensitive for my taste.
pidd
Tue Apr 20, 2021 1:49 am
The Pi has moved on very fast, generally any information more than 6 months old needs to be double checked, any problems more than 6 months old are highly unlikely to still be a problem.
drgeoff
Tue Apr 20, 2021 7:01 pm
I don't see anything there that singles out having number pads as the reason for devices not working.
Odyknuck
Wed Apr 21, 2021 1:14 am
I suppose I should have worded it in a different way for that link. Its the wireless part that's the issue. I have however read in other places about the keypad not always functioning correctly. I am not going to try and figure out where lol. Mine works so it's now a mute issue for me.
Wed Apr 21, 2021 7:05 am
I do like a silent issue.
brucewestfall
Sun Apr 25, 2021 7:31 pm
A USB wireless keyboard and mouse do work.
As of April 25th, 2021 a wireless logitech mouse with a USB dongle works perfectly on a pi400. Number pad works like it should and little white keyboard also works at the same time. You could be like that horrible scene on NCIS where Abby and Mcgee are both typing away on a keyboard at the same time. But you can each have your own here.
Prepare for a total geek cringe on this one if you havent seen it! https://www.youtube.com/watch?v=msX4oAXpvUE
