rin67630
How to start using minicom?
Sat Apr 17, 2021 7:57 pm
Hi
I need a plain terminal program on /dev/ttyUSB0.
I have installed minicom and started it with
minicom /s.
The default port is a non-existing /dev/usb8
After having set the port to /dev/ttyUSB0 i wanted to save the settings to dlf, but it failed due to missing permissions.
Doing the same with sudo minicom worked, but is saves the dlf to the root user.
Now i can't start minicom normally even with minicom /s:
minicom /s
minicom: cannot open /dev/tty8: Permission denied.
That was not a nice start...
How shout it have been to work flawlessly?
Thank you for advice.
P.S. maybe you can recommend another program?:
I just want to be able to type some commands and get lists on /dev/ttyUSB0.
scruss
Re: How to start using minicom?
Sat Apr 17, 2021 10:11 pm
minicom --setup
will always try to save your setup into /etc/minicom - which will fail as a regular user.
So if you always want that setting to stick, create the file ~/.minirc.dfl and put this line in it:
pu port             /dev/ttyUSB0
Once this file exists, defaults should be saved to it rather than the root file in /etc
Alternatively, since I can't always rely on having a good default setup, I specify parameters from the command line:
minicom --device /dev/ttyUSB0 --baudrate 115200
The latest desktop update installed a terminal program - gtkterm, or somesuch. Not much use if you're running headless.
Pronouns: he/him
swampdog
Sat Apr 17, 2021 10:28 pm
I use minicom on rpi that have rs232 adapters attached into PC's (where I always 'sudo -i minicom') but for the USB->tty adapter I just use 'screen'..
foo@sdu /kvm $ cat /usr/local/sd/bin/rpi-tty0
#!/bin/bash
echo "^D to leave.."
sleep 1
sudo screen /dev/ttyUSB0 115200
GlowInTheDark
Sat Apr 17, 2021 10:36 pm
sudo???
Anyway, the best answer to the Subject: title question is: DON'T.
(As you imply) Use screen instead. But don't use sudo...
GitD's list of things that are not ready for prime time:
1) IPv6
2) 64 bit OSes
3) USB 3
4) Bluetooth
Loves Linux; loves to dance.
swampdog
Sun Apr 18, 2021 12:19 am
Possibly, but we don't know where the USB end of that device is plugged in. Another rpi or equally likely a linux PC. Unfortunately I don't know where my USB->tty adapter is, so dunno what group that device appears as. I suspect it's a moot point though because we look at my rpi with a serial rs232..
A buster rpiZW..
foo@pi13:~ $ lc -d /dev/ser*
lrwxrwxrwx 1 root root 7 Feb  5 03:37 /dev/serial0 -> ttyAMA0
lrwxrwxrwx 1 root root 5 Feb  5 03:37 /dev/serial1 -> ttyS0
foo@pi13:~ $ lc -d /dev/tty* | egrep "(AM|S0)"
crw-rw---- 1 root dialout 204, 64 Apr 17 22:27 /dev/ttyAMA0
crw-rw---- 1 root dialout   4, 64 Feb  5 03:37 /dev/ttyS0
A buster rpi4..
foo@pi18:~ $ lc -d /dev/ser*
lrwxrwxrwx 1 root root 5 Apr  1 08:17 /dev/serial0 -> ttyS0
lrwxrwxrwx 1 root root 7 Apr  1 08:17 /dev/serial1 -> ttyAMA0
foo@pi18:~ $ lc -d /dev/tty* | egrep "(AM|S0)"
crw-rw---- 1 root dialout 204, 64 Apr  1 08:34 /dev/ttyAMA0
crw--w---- 1 root tty       4, 64 Apr  2 21:12 /dev/ttyS0
On a (linux mint) PC with a serial port..
guy@std ~ $ grep ^GRUB_CMDLINE_LINUX_DEFAULT /etc/default/grub
GRUB_CMDLINE_LINUX_DEFAULT="console=tty0 console=ttyS0"
guy@std ~ $ ls -l /dev/tty0 /dev/ttyS0
crw--w---- 1 root tty 4,  0 Apr 17 12:15 /dev/tty0
crw--w---- 1 root tty 4, 64 Apr 17 12:16 /dev/ttyS0
So on rpiZW I can add "dialout" to "foo" but it won't work for both cases in rpi4. Similarly its "tty" in both cases on that PC but will work in neither case. This is one of those rare cases where sudo *is* the answer.
cleverca22
Sun Apr 18, 2021 1:02 am
if the serial port is in the tty group, then its got a login prompt running on it, using sudo to force things will just lead to more problems*
you need to remove the console=serial0 from /boot/cmdline.txt, then the login prompt will go away and it will instead be in the dialout group
*: with a getty running on the port, it will randomly steal bytes being sent into the pi, and spit out error messages about an invalid username
scruss
Sun Apr 18, 2021 3:13 am
screen is very limited compared to minicom. I'll use it if it's all I have, but minicom does so much more.
All of them are frankly small-fry compared to kermit, but its usability is quite poor.
Pronouns: he/him
GlowInTheDark
Sun Apr 18, 2021 8:31 am
I'm not saying you're wrong, but I've never felt any limitations in screen. What does minicom do that screen doesn't do?
(Again, I'm not saying otherwise; am genuinely curious).
But the overriding point is that, as I've said many times in the past - whenever the name "minicom" is mentioned - I've never met a program that tried so hard to (and succeeded so well at) being hard to use.
Anyway, as I have also mentioned many times in the past - whenever the subject of "serial comm" programs has come up - the best (IMHO) serial program for the Linux platform is Seyon.
Edit to add: Also, in wandering around the filesystem, I also found /usr/bin/miniterm.py
No idea if it is any good or not, but as it is Python source - it might be user-extendable into something useful.
1) IPv6
2) 64 bit OSes
3) USB 3
4) Bluetooth
JumpZero
Sun Apr 18, 2021 11:24 am
I was a screen user for years, and continue to use it from time to time, but I now use most of the time miniterm or minicom.
miniterm is very easy and is part of python py-serial (and gives the option to change the default exit hotkey because the Ctrl-[ isn't convenient on non-us keyboard)
I feel they are all the same, once you are connected to the device, you forget them.
To connect to MicroPython devices rshell is my favorite choice.
scruss
Sun Apr 18, 2021 4:09 pm
File transfers, with all protocols configurable. Controlled-speed text file transfer is the big one for me. Some of the computers I use are too old or too small to support any error-correcting protocols, so sometimes you just have to pretend you're typing. Niche, I know.
screen's eating Ctrl-A as a useful character is a huge annoyance. Minicom eats a few keys too, but not ones that so readily clash with software I'm used to. If only minicom would support Mark parity better: I have a device that uses 7M1 (so 7 data bits, one parity bit, but always set it to 1) so it's Kermit for that one.
I'd agree. I think a lot has to do with the way Debian sets it up. By having no system config files in /etc, and no user-writeable configuration files created on first startup, it's very hard to save settings at all.
If we're on the subject of special-purpose serial things, Grabserial is entirely awesome for non-interactive logging from a serial device. I see it's now added timestamping and file splitting: both handy features I'd wished it had in the past
Pronouns: he/him
swampdog
Sun Apr 18, 2021 10:15 pm
^^^I've not seen this.
Is this information not correct https://learn.adafruit.com/adafruits-ra ... -configure (Linux section)?
I seem to have..
foo@pi18:~ $ cat /boot/cmdline.txt
dwc_otg.lpm_enable=0 console=serial0,115200 console=tty1 root=/dev/mapper/pi18-root rootfstype=ext4 elevator=deadline fsck.repair=yes rootwait
..which must have worked fine when I set it up. It was a long time ago so cannot recall if it was a usb->tty or rs232 which was used.
cleverca22
Mon Apr 19, 2021 4:39 am
I seem to have..
that is how to use a usb serial adapter on another system, to access the login prompt of the rpi
the console=serial0,115200 causes linux to run a login prompt on the serial port, which will then conflict with any non-console thing your trying to do over the serial port
https://www.raspberrypi.org/documentati ... on/uart.md
that is the official docs on how to configure the rpi end of the serial link
swampdog
Tue Apr 20, 2021 9:31 pm
Looks like I misread the intent of the OP. oops! :-|
fanoush
Wed Apr 21, 2021 10:26 am
There is also picocom https://linux.die.net/man/8/picocom
Somehow I like it. It is simpler and easier to use version of minicom, I can
just run e.g. 'picocom -b115200 /dev/ttyUSB0' and no messing with menu or configuration needed. ctrl-a-x to exit.
GlowInTheDark
Wed Apr 21, 2021 2:36 pm
To amplify on this further, I think it is a fundamental design flaw - a clear cut instance of "Broken by design" - if a system requires root access in order to configure personal user settings - i.e., settings that every user will need to configure, and which affect no one else on the system.
The two instances of this that I am aware of in Raspbian are:
1) minicom - which is what makes it so hard to use and why I always recommend against it.
2) The LXDE "autostart" file - which is stored in /etc (*) and needs root to edit.
Which is what makes it so hard to use and why I always recommend against it.
(*) At least for the time being. Who knows where they'll store it in the next OS release???!
1) IPv6
2) 64 bit OSes
3) USB 3
4) Bluetooth
rin67630
Fri Apr 23, 2021 4:16 pm
minicom --setup
Thank you!
It helped me.
But the devs at minicom should admit that is is not intuitive and not user friendly.
rin67630
Fri Apr 23, 2021 4:19 pm
1) Full ack!
2) At least I can understand that an autostart needs admin privileges.
rin67630
Fri Apr 23, 2021 4:54 pm
Meanwhile i have installed GtkTerm, not a wonder-weapon but does what I need.
scruss
Fri Apr 23, 2021 5:21 pm
I think minicom's old enough (pre-2000, at any rate) that the old advice of "make a copy of the system config in $HOME so the user can have their own setup" rule-of-thumb has been forgotten. I just remember a Unix tutorial as a first-year student where the first command you were supposed to type was something like cat /etc/csh.cshrc > .cshrc to set up your own options. This would have been a SunOS machine, c.1988.
New user setup on Linux does this automatically by copying files from /etc/skel/ . minicom could do something similar. It seems that no-one has raised a bug about this in all the years that this has been a Debian package. Minicom's got outstanding wishlist bug reports going back to 1998, so I wouldn't expect this to be fixed quickly.
GtkTerm seems to be supplied as part of the latest system update
Pronouns: he/him
