David_amsalem_99
Using a display through the Dsi port
Fri Jul 24, 2020 3:09 pm
I've got an old TFT display (with touch) and i wondering if i can use it from the dsi port like the official raspberry pi screen is doing?
If possible, what are the options?
mahjongg
Re: Using a display through the Dsi port
Fri Jul 24, 2020 3:11 pm
No you can't.
aBUGSworstnightmare
Fri Jul 24, 2020 4:19 pm
do you know details of your display? Is it MIPI-DSI at all?
David_amsalem_99
Sat Jul 25, 2020 5:19 pm
I know it's from a Samsung tablet a series it is mipi with 50 pins
aBUGSworstnightmare
Sat Jul 25, 2020 7:31 pm
well, you need to have the data sheet for the timing and init sequence, a Raberry Compute Moduk (as there is the risk that yoir display will use more than 2-lane MIPI) and some knowledge in how to interfave it. Last but not least you will have to write a display driver ...
David_amsalem_99
Sun Jul 26, 2020 7:49 am
Sounds like I've got a lot of work to do and a lot to study :)
Few more questions
Is the compute module is for testing or it has a different job?
can i convert between different lane count?
Where can i best learn about writing driver?
