wahid.majri
How to change port? From /dev/ttyACM0 to /dev/ttyUSB0
Sat Jul 25, 2020 8:35 pm
How to change port? From /dev/ttyACM0 to /dev/ttyUSB0 in raspberry pi4
B.Goode
Re: How to change port? From /dev/ttyACM0 to /dev/ttyUSB0
Sat Jul 25, 2020 10:17 pm
Context?
What Operating System is running on your RPi4 board?
In what application, tool, utility or programming language do you want to make this change?
scruss
Sun Jul 26, 2020 12:25 am
You can't - or at least, not easily.
If a serial device identifies as a Abstract Control Model (ACM) device, the kernel has assigned the name before you can do anything with it. There might be a udev rule you can apply, possibly, to fix the name.
Do you have an application that will only work with /dev/ttyUSB* devices? Because /dev/ttyACM* should behave the same way.
Pronouns: he/him
wahid.majri
Sun Jul 26, 2020 5:32 pm
Context?
Raspbian OS
python3
B.Goode
Sun Jul 26, 2020 5:49 pm
Context?
Raspbian OS
python3
With so little information, the only possible answer has to be something vague like "change that string in the script you are using."
