Ivanhosa13
ESP32 and MQTT
Thu Feb 13, 2020 11:22 pm
I am using a raspberry pi 3 and a ESP32. I am trying to make the ESP 32 (the client) communicate wirelessly with the pi being used as a broker. i need some help with a code that will make ESP32 connect automatically with the MQTT.
this is the code i am currently using.
from time import sleep
from umqtt.simple import MQTTClient
from machine import Pin
from dht import DHT22
SERVER = '192.168.1.22'  # MQTT Server Address (Change to the IP address of your Pi)
CLIENT_ID = 'ESP32_DHT22_Sensor'
TOPIC = b'temp_humidity'
client = MQTTClient(CLIENT_ID, SERVER)
client.connect()   # Connect to MQTT broker
sensor = DHT22(Pin(15, Pin.IN, Pin.PULL_UP))   # DHT-22 on GPIO 15 (input with internal pull-up resistor)
while True:
    try:
        sensor.measure()   # Poll sensor
        t = sensor.temperature()
        h = sensor.humidity()
        if isinstance(t, float) and isinstance(h, float):  # Confirm sensor results are numeric
            msg = (b'{0:3.1f},{1:3.1f}'.format(t, h))
            client.publish(TOPIC, msg)  # Publish sensor data to MQTT topic
            print(msg)
        else:
            print('Invalid sensor readings.')
    except OSError:
        print('Failed to read sensor.')
    sleep(4)
credits to https://www.rototron.info/raspberry-pi- ... -tutorial/
DirkS
Re: ESP32 and MQTT
Fri Feb 14, 2020 3:57 am
You're asking about (Micropython?) code on an ESP32, so it has nothing to do with Pi...
Anyway, what is the problem with your code? Error messages?
Ivanhosa13
Re: ESP32 and MQTT
Fri Feb 14, 2020 2:42 pm
I'm not getting errors, but when ever I restart the ESP32. It doesn’t connect back the Mqtt , I have to go back to REPL and import the code that we submit to work so all I want it to do is to connect to the Mqtt by it self.
B.Goode
Re: ESP32 and MQTT
Fri Feb 14, 2020 5:24 pm
While still noting that this isn't an RPi query...
Does your esp32 board have an association with a wireless access point to allow network connectivity with the mqtt broker at the time your esp32 sensor client runs?
Ivanhosa13
Re: ESP32 and MQTT
Fri Feb 14, 2020 7:14 pm
Yes, I am trying to make the pi the wireless access point.
This is the code I'm using on the pi
import paho.mqtt.client as mqtt
import Adafruit_SSD1306
from PIL import Image, ImageDraw, ImageFont
disp = Adafruit_SSD1306.SSD1306_128_32(rst=0)
disp.begin()
FONT_PATH = '/usr/share/fonts/truetype/piboto/PibotoCondensed-Regular.ttf'
FONT = ImageFont.truetype(FONT_PATH, 22)
def display_data(t, h):
    image = Image.new('1', (disp.width, disp.height))
    draw = ImageDraw.Draw(image)
    # Draw temperature / Humidity values.
    draw.text((0, 8), '{0}°C'.format(t),  font=FONT, fill=255)
    draw.text((71, 8), '{0}%'.format(h), font=FONT, fill=255)
    # Draw bar charts.
    draw.rectangle((0, 0, 50, 8), outline=255, fill=0)
    draw.rectangle((71, 0, 121, 8), outline=255, fill=0)
    draw.rectangle((0, 0, t / 100.0 * 50, 8), outline=255, fill=255)
    draw.rectangle((71, 0, 71 + (h / 100.0 * 50), 8), outline=255, fill=255)
    # Send to OLED display.
    disp.clear()
    disp.image(image)
    disp.display()
	# Callback fires when conected to MQTT broker.
def on_connect(client, userdata, flags, rc):
    print('Connected with result code {0}'.format(rc))
    # Subscribe (or renew if reconnect).
    client.subscribe('temp_humidity')
# Callback fires when a published message is received.
def on_message(client, userdata, msg):
	# Decode temperature and humidity values from binary message paylod.
    t,h = [float(x) for x in msg.payload.decode("utf-8").split(',')]
    print('{0}°C {1}%'.format(t, h))
    display_data(t, h)  # Display data on OLED display.
client = mqtt.Client()
client.on_connect = on_connect  # Specify on_connect callback
client.on_message = on_message  # Specify on_message callback
client.connect('localhost', 1883, 60)  # Connect to MQTT broker (also running on Pi).
# Processes MQTT network traffic, callbacks and reconnections. (Blocking)
client.loop_forever()
B.Goode
Re: ESP32 and MQTT
Fri Feb 14, 2020 7:23 pm
I thought the outstanding substantive question was -
The script that subscribes to the mqtt broker is not relevant if the publisher client on the esp32 does not have a working wireless connection.
Ivanhosa13
Re: ESP32 and MQTT
Fri Feb 14, 2020 9:00 pm
I do have a code that connects the ESP32 to the WiFi automatically when I reset the ESP32 and it is the same WiFi that the pi is connected too. The code is in a different script and called main.py
 import network
station = network.WLAN(network.STA_IF)
station.active(True)
station.connect("<your ssid>", "<password>")
B.Goode
Re: ESP32 and MQTT
Fri Feb 14, 2020 9:08 pm
 import network
1. Does this main.py script run to completion to put the esp32 online before the sensor publisher client script starts running.
2. " it is the same WiFi that the pi is connected too" - I thought you were configuring the RPi to act as an Access Point/Hotspot?
Ivanhosa13
Re: ESP32 and MQTT
Fri Feb 14, 2020 9:23 pm
Yes sir, the main.py script run to completion to put the esp32 online before the sensor publisher client script starts running.
Another thing, I am using Rshell to access the ESP32 using the raspberry pi. And from there I got REPL and from there I hit the rest bottom and it shows that the ESP32 is connected to the WiFi but I doesn’t connect to the mqtt, so I have to import the dht_publish which is this code
while True:
    try:
            print(msg)
        else:
    except OSError:
    sleep(4)
To make it work.
Also , I am new to all these stuff so excuse me if I am making mistakes explaining the stuff
B.Goode
Re: ESP32 and MQTT
Fri Feb 14, 2020 9:31 pm
I will not be providing any further esp32 support in this Raspberry Pi forum.
DirkS
Re: ESP32 and MQTT
Fri Feb 14, 2020 10:57 pm
Indeed. This is way off topic for this forum
