beduino
Anki not is working
Wed Aug 14, 2019 2:57 am
Hello, this is the error:
$ sudo anki
  File "/usr/bin/anki", line 7, in <module>
    import aqt
  File "/usr/share/anki/aqt/__init__.py", line 12, in <module>
    from aqt.qt import *
  File "/usr/share/anki/aqt/qt.py", line 22, in <module>
    from PyQt4.QtWebKit import QWebPage, QWebView, QWebSettings
ImportError: No module named QtWebKit
help me please! :lol:
pcmanbob
Re: Anki not is working
Wed Aug 14, 2019 9:10 am
From the little information supplied
the module named QtWebKit is not installed or its not installed for the version of python that is trying to use it.
not much else that can offered in the way of help on the information supplied.
see the second line in my signature.
beduino
Thu Aug 15, 2019 3:17 am
Yes, for me this is a dependency that is not in the repositories. I'm using a raspberry pi 3B+ with raspbian 9. I was wondering if anyone else tried to install this app and was unable to run it. We need more technical support. :D
pcmanbob
Thu Aug 15, 2019 12:30 pm
OK so you did not take the hint.
So I will spell it out we need more information to be able to help you
for a start what instructions are you following to install Anki on your pi and which OS are you running on your pi
Thu Aug 15, 2019 2:25 pm
That question was answered, at least
So Stretch.
ShiftPlusOne
Thu Aug 15, 2019 2:37 pm
Not sure how up to date my information is or how accurate my memory is, but I seem to recall looking into it and it's just that one of the dependency packages is too much of a hassle to build for the pi, so it wasn't included in Raspbian.
beduino
Sun Aug 18, 2019 11:40 pm
Thanks my friend for your support, but the solution were to use the AnkiDroid in the smartphone. Probably the Anki have not support on Debian Stretch.
Return to “Python”
