genivx
any way to fix the microSD card reader on the P3b+?
Fri Sep 14, 2018 5:43 am
I got three Pi3B+
one of the units seems to have issue reading microsd card.
the same card/image works on the other two PIs
that bad one it worked initially but when I took the card out to rewrite it it could never read the card again or any other card while the other two reads it fine.
I don't see the green read light when it powers on :(
Re: any way to fix the microSD card reader on the P3b+?
Fri Sep 14, 2018 11:33 am
You should assume that the SDCard has gone bad, before anything else. Try it in another RPi. Try sticking a new copy of plain Raspbian on it with Etcher. Try a factory fresh SDCard.
Your 3B+ supports booting from a USB device. Try that to prove whether the board works or not.
You may be looking at a £35 fix for your problem.
This is a hippy & doctor free zone.
B.Goode
Fri Sep 14, 2018 11:58 am
The suggestion to try booting the suspect RPi from mass storage is worthwhile, since it may be more than the microSD card reader that has faulted.
genivx
Fri Sep 14, 2018 9:19 pm
don't you have to do some configuration first to get the R3B+ to boot off a USB device? boot from USB is not enabled by default.
I tried 3 different cards on this Pie and it won't read/boot. those cards work on my oher PIs fine.
unless I did it wrong I did write an image to a usb stick and tried to boot from that. didn't work though.
might have to scrap this unit.
Fri Sep 14, 2018 9:23 pm
It's enabled in the factory on RPi3B+
davidcoton
Fri Sep 14, 2018 9:27 pm
EDIT: this may not be relevant if all your Pis are Pi3B+
Not all images will work on a Pi3B+. Try a new download of the latest Raspbian.
Older Raspbian Stretch images can be updated on an older Pi:
sudo apt update
sudo apt full-update
Older Raspbian (Jessie, Wheezy) and other OSs are more tricky -- results not guaranteed.
You need to say what OS and its version/date and maybe someone can help.
Likewise NOOBS can be updated but a new image is easier.
Signature retired
genivx
Fri Sep 14, 2018 9:45 pm
I will try again when I get home but this image was downloade from the raspberry pi website about under 2 months ago.
any specific image that you guys recommend to burn to a usb drive to boot it? (or any specific software to use?)
thanks alot everyone
Fri Sep 14, 2018 10:35 pm
Plain Raspbian Stretch & Etcher.io (to write it to your USB stick).
genivx
Sat Sep 15, 2018 5:26 am
just tried it again no go.
might not even be the card reader. might the main board.
gonna toss this one away
Burngate
Sat Sep 15, 2018 7:46 am
Before you toss it, it might be worth looking in the card slot for physical damage - bent pins, &c.
hippy
Sat Sep 15, 2018 6:53 pm
It would be worth seeing what "return, test, repair or replace" service the retailer you bought it from offers. It may even be covered by warranty.
