eee123
3b+ startup/shutdown button
Mon Jun 25, 2018 2:53 pm
trying to get an access point (working) AND a shutdown button script to work on startup...
when i run the button script separately in terminal it works, but not when its started on boot automatically via rc.local
even running rc.local directly with: sudo /etc/rc.local makes it work, but it does not run at startup so i may have an rc.local startup issue
adding the shutdown button script to the rc.local doesnt work, as per this guide:
https://www.element14.com/community/doc ... berry-pi-b
nor does it work going the direct route as per this guide:
https://howchoo.com/g/mwnlytk3zmm/how-t ... spberry-pi
nor does it work as per this guide:
http://www.instructables.com/id/Simple- ... wn-Button/
trying to run it off GPIO3 so i can have a combined shutdown/startup button
any help/ideas appreciated
eee123
Re: 3b+ startup/shutdown button
Mon Jun 25, 2018 3:03 pm
does the issue have something to do with the message i get when i run the script:
runtime warning "A physical pull up resistor is fitted on this channel!"
when using GPIO 3 (pin 5.)
so cant use GPIO 3 regardless of it having the ability to startup/shutdown the pi?
although im unsure because i previously tried GPIO 27 and that wasn't working either...
klricks
Mon Jun 25, 2018 7:07 pm
See my reply here: viewtopic.php?f=28&t=216586
Unless specified otherwise my response is based on the latest and fully updated Raspbian Stretch w/ Desktop OS.
eee123
Wed Jun 27, 2018 2:01 pm
thank you very much, fixed my issue completely!
