Shane Angle
Viewing my usb webcam outside home network
Tue Apr 03, 2018 9:37 pm
I have set up my pi server and port set to 8081 and able to view this in my home network but id like to be able to access the webcam with my webpage with password protection of course... ANY SUGGESTIONS?
drgeoff
Re: Viewing my usb webcam outside home network
Tue Apr 03, 2018 10:36 pm
I suggest you acquaint yourself with the basic principles of port forwarding and the specifics of how to accomplish it on your particular model of router. Neither is specific to using a RPi. Any decent search engine will return many web pages with the required information on both port forwarding and incorporating password handling in a web page. Your router manual should cover how to configure port forwarding on it.
Shane Angle
Tue Apr 03, 2018 10:56 pm
I have already enabled port forwarding for my pi address and have a working website with my password protected access but the webcam is set on port 8081 and not 8080 which is the port im using for my site... I can only enter this area if im connected in my home network[
drgeoff
Wed Apr 04, 2018 8:11 am
drgeoff
Wed Apr 04, 2018 8:13 am
Have you tried port forwarding 8081 to the RPi in addition to 8080?
Shane Angle
Wed Apr 04, 2018 3:33 pm
Yes it is an invalid port
drgeoff
Wed Apr 04, 2018 4:22 pm
What says that?
Shane Angle
Wed Apr 04, 2018 4:58 pm
The router does I would like to view outside my network 8080(server), 8081(webcam) and 1880(node-red ui) but not having any luck only 8080 is visible outside the home network
drgeoff
Mon Apr 16, 2018 10:40 pm
Shane Angle wrote:
Mon Apr 16, 2018 5:52 pm
viewtopic.php?f=62&t=209914c
From which it appears that my answer above namely "I suggest you acquaint yourself with the basic principles of port forwarding " was pertinent.
Shane Angle
Tue Apr 17, 2018 1:26 am
It was a mistake in my HTML code not port forwarding
drgeoff
Tue Apr 17, 2018 8:03 am
AIUI your code contained the LAN address instead of the WAN address. You knew how to do port forwarding but did not understand how port forwarding was only a part of the whole private LAN, public internet, NAT router configuration.
Shane Angle
Wed Apr 18, 2018 11:23 pm
I will agree... my question would be since my pi is running on the same local ip address why would I need to use the WAN address? hypothetically shouldn't I be able to point it in the direction of the port? like addressing a gif image in your html in the same file as your code? :?:
