beatsal
SD CARD copier
Sun Jan 21, 2018 12:14 am
This is in accessories of PI. How does it work? I want to copy from 1 SD to another. Do I need 2 PIs working at same time for this?
Re: SD CARD copier
Sun Jan 21, 2018 12:24 am
You need a USB SDHC Card Reader.
adieu
My other Computer is an Asus CS10 ChromeBit
beatsal
Re: SD CARD copier
Sun Jan 21, 2018 12:55 am
Thanks. Not familiar with this. So I stick the reader on the computer USB port and copy to the RPI directly?
klricks
Re: SD CARD copier
Sun Jan 21, 2018 1:30 am
No.
You connect the cardreader to a USB port on the RPi. The SD card (Running OS) in the RPi is then copied to the SD card in the cardreader.
Unless specified otherwise my response is based on the latest and fully updated Raspbian Stretch w/ Desktop OS.
B.Goode
Re: SD CARD copier
Sun Jan 21, 2018 8:35 am
Rather than 'ping pong' questions here, maybe you should read what the Raspberry Pi Foundation wrote in the blog post that introduced this utility 18 months ago?
See https://www.raspberrypi.org/blog/anothe ... -raspbian/, under the heading SD card copier.
