MuntyScruntfundle
Unable to contact mirrordirector.aspbian.org
Thu Dec 07, 2017 1:27 pm
Does this mean maintenance or misbehaviour is happening at the org, or could it be a problem with a pi?
I'm getting a load of these while trying to update/upgrade this particular pi, and install spe and some other software. I've had this before, but everything appeared to work fine a couple of hours later. That leads me to believe it isn't a problem at my end, but I thought I'd check.
Thanks.
Re: Unable to contact mirrordirector.aspbian.org
Thu Dec 07, 2017 1:40 pm
It more likely means your keyboard is broken.
It's https://mirrordirector.raspbian.org [with an arrrr]
If that doesn't route to a sensible mirror server then take a look at https://raspbian.org/RaspbianMirrors to find a local mirror that does work. You can hard code it into your /etc/apt/sources.list and /etc/apt/sources.list.d/*.list files (as a temporary work-around).
Microprocessor, Raspberry Pi & Arduino Hacker
Mainframe database troubleshooter
MQTT Evangelist
Twitter: @DougieLawson
2012-18: 1B*5, 2B*2, B+, A+, Z, ZW, 3Bs*3, 3B+
HawaiianPi
Thu Dec 07, 2017 8:06 pm
Except when this sort of thing happens, the mirror list is also often offline as well. Try a google cache of the page.
https://webcache.googleusercontent.com/ ... clnk&gl=uk
Who is online
Users browsing this forum: Bing [Bot], pertm84 and 48 guests
