daveake
Pi Zero W Serial Port
Fri Mar 03, 2017 4:21 pm
Before I try it, if I want to use the full serial port device on the Pi Zero W, should I use the same overlay as on the Pi V3, i.e.:
dtoverlay=pi3-disable-bt
or is there or will there be an overlay specific to the Zero W ?
Dave
el_pombo
Re: Pi Zero W Serial Port
Fri Mar 10, 2017 6:18 pm
Did you get to any conclusion on this? It seems the pi3 overlay does not work!
All the best!
el_pombo
Fri Mar 10, 2017 6:43 pm
The problem is that I want to have both full serial and Bluetooth on the miniuart, with the pi3 I used dtoverlay=pi3-miniuart-bt, but if I use this with pi zero w I get the full serial on ttyAMA0 but hcitool can't detect any devices for bluetooth.
dgordon42
Sat Mar 11, 2017 12:17 pm
el_pombo wrote:with the pi3 I used dtoverlay=pi3-miniuart-bt, but if I use this with pi zero w I get the full serial on ttyAMA0 but hcitool can't detect any devices for bluetooth.
Have you also added "core_freq=250" to the '/boot/config.txt' file?
Without this additional step the mini-UART won't work with Bluetooth on the Pi 3b. I suspect this is also the case with the Pi Zero W. (I don't have one to test this on)
The details are in the '/boot/overlays/README' file.
Hope this helps,
Dave.
el_pombo
Sat Mar 11, 2017 1:18 pm
Hope this helps,
Dave.
Hi, thanks for your reply!
I've done that yesterday (core_freq and serial1), but it didn't work, hcitool returns nothing!
All the best!
sghh1970
Thu Sep 14, 2017 3:03 pm
did you find a resolution? I have the same issue.
My config.txt:
dtoverlay=enc28j60,int_pin=25,speed=12000000
core_freq=250
dtparam=audio=on
dtoverlay=midi-uart1
It works with the pi3 and not the pi zero w.
Thanks,
Who is online
Users browsing this forum: LtShinySides, MaxK1 and 50 guests
