mad-hatter
Debian Wheezy on a PC and BD-RE Blu-Ray Disks.
Wed Feb 04, 2015 9:52 pm
Trying to write a re-writeable BD-RE disk on a dual boot PC, Windows 7 / Debian Wheezy OS.
uname -a
Linux myPC 3.2.0-4-amd64 #1 SMP Debian 3.2.65-1+deb7u1 x86_64 GNU/Linux
The disk is formatted under Windows 7 as a UDF 2.5 file system.
I can drag & drop files under Windows with ease. What I can't do is get linux to access the disk.
I get these errors using Dolphin
DBus error org.gtk.Private.RemoteVolumeMonitor.Failed:
An operation is already pending
Error mounting: mount exited with exit code 1: helper failed with:
mount: block device /dev/sr0 is write-protected, mounting read-only
mount: wrong fs type, bad option, bad superblock on /dev/sr0,
       missing codepage or helper program, or other error
       In some cases useful info is found in syslog - try
       dmesg | tail  or so
$ dmesg | tail
[  423.344515] UDF-fs: error (device sr0): udf_load_partdesc: error loading MetaData partition map 1
[  423.344592] UDF-fs: error (device sr0): __udf_read_inode: (ino 4294967295) failed !bh
[  423.344598] UDF-fs: warning (device sr0): udf_find_metadata_inode_efe: metadata inode efe not found
[  423.344604] UDF-fs: error (device sr0): __udf_read_inode: (ino 4294967295) failed !bh
[  423.344610] UDF-fs: warning (device sr0): udf_find_metadata_inode_efe: metadata inode efe not found
[  423.344617] UDF-fs: error (device sr0): udf_load_metadata_files: Both metadata and mirror metadata inode efe can not found
[  423.344624] UDF-fs: error (device sr0): udf_load_partdesc: error loading MetaData partition map 1
[  425.843513] UDF-fs: warning (device sr0): udf_load_vrs: No anchor found
[  425.843520] UDF-fs: warning (device sr0): udf_fill_super: No partition found (1)
[  426.082183] ISOFS: Unable to identify CD-ROM format.
I can use filezilla to drag & drop, to and from the RPi.
Any body know, what linux software I need to install on the PC to access the disk?
Thanks in advance.
Regards
