NOOBS Software in Laptop?
Posted: Wed Mar 26, 2014 9:37 am
by ruphert
I'm new here and not much familiar in Pi. Does NOOBS software which I found here
http://swag.raspberrypi.org/collections ... ucts/noobs can be install even in laptop?
Re: NOOBS Software in Laptop?
Posted: Wed Mar 26, 2014 9:56 am
by fruitoftheloom
Deseigned for Pi only, the Pi is based around an ARMv6 CPU, your Windows Laptop is a x86 CPU, different architecture:
http://www.raspberrypi.org/archives/4100
Posted: Wed Mar 26, 2014 2:26 pm
by FTrevorGowen
fruitoftheloom wrote:Deseigned for Pi only, the Pi is based around an ARMv6 CPU, your Windows Laptop is a x86 CPU, different architecture:
+1
However, you can use your laptop/netbook to copy the "NOOBS installer" software onto an empty and/or freshly formatted SDHC card ready for use in a Pi. As indicated above, the NOOBS software itself will only boot and run on a Pi subsequently presenting you with a choice of (mainly Linux) O.S.'s to be installed on the same SDHC card which, on re-boot will run on the Pi.
FWIW, see my "screenshot-based guides" here:
http://www.cpmspectrepi.webspace.virgin ... lV132.html
Trev.
Posted: Tue Apr 08, 2014 3:28 am
by ruphert
Thank you!
Posted: Thu Aug 07, 2014 9:31 pm
by Hypersniper118
Is it possible to boot a laptop with no hard drive of a SD card with raspberry pi software on it
Posted: Fri Aug 08, 2014 5:08 am
by fruitoftheloom
Hypersniper118 wrote:Is it possible to boot a laptop with no hard drive of a SD card with raspberry pi software on it
The Raspberry Pi uses the ARM architecture, Windows Laptop use x86 architecture, so not possible.......
Posted: Fri Aug 08, 2014 6:38 am
by dan3008
Some older netbooks use ARM, but even then, its a diffrent version to the pi, so wont work.
Your best bet, if you want a "pi like" exsperiance, is to install debian, or lubuntu on your laptop. Thats what I'm doing :)
Posted: Fri Aug 08, 2014 7:49 am
by fruitoftheloom
dan3008 wrote:Some older netbooks use ARM, but even then, its a diffrent version to the pi, so wont work.
Using Linux is what all sensible people do.... :shock:
