cleverca22
Re: voicecommand
Thu Mar 20, 2014 3:46 am
sudo apt-get install libboost-regex1.49.0
syde0004
Re: voicecommand
Wed Dec 09, 2015 10:25 pm
Has anybody figured anything out with this? I'm running into the same issue and feel like I'm beating my head against a wall.
G3N13
Re: voicecommand
Wed Jan 13, 2016 9:55 am
I too am having this same exact issue. If any of you have figured it out by now, please let me know! Much appreciated, Thanks
pilou100
Re: voicecommand
Sun Apr 17, 2016 11:08 am
Same one here... too bad :( :( :(
Re: voicecommand
Sun Apr 17, 2016 3:18 pm
sudo apt-get install libboost libboost-regex libboost-dev libboost-regex-dev
This is a doctor free zone.
pbecks1963
Re: voicecommand
Fri Apr 29, 2016 2:20 pm
@DougieLawson
i get the error:
e: unable to locate package libboost libboost-regex libboost-regex-dev
Re: voicecommand
Fri Apr 29, 2016 8:26 pm
Sorry I have no idea how to solve that because my crystal ball went off line a few years ago. You've not given enough detail.
What OS? Are you connected to the internet? Are your apt-get files up to date?
pbecks1963
Re: voicecommand
Tue May 03, 2016 10:55 am
Sorry Dougie... (nevermind)
meanwhile i have changed a lot (changed to raspbian jessie and "jasper"). Things are still not working properly but i am not giving up...
androidvoir
Re: voicecommand
Fri May 06, 2016 12:55 pm
I have been trying to get voicecommand to work on Jessie and this is what worked for me:
git clone git://github.com/StevenHickson/PiAUISuite.git
cd PiAUISuite/Install/
./InstallAUISuite.sh
cd PiAUISuite/VoiceCommand
make clean
g++ -mcpu=cortex-a7 -mfpu=neon-vfpv4 -mfloat-abi=hard -D'BUILDTS="160506 05:20:31 -0700"' -O3 -lcurl -lboost_regex -o voicecommand voicecommand.cpp
cp voicecommand /usr/bin
voicecommand -s
make by itself kept trying to use g++-4.8 ... I have tried a bunch of other projects out there including pocketsphinx (some success) and Jasper building manually because I don't want to start from a fresh image (no success)
theseamusjames
Re: voicecommand
Sun May 08, 2016 6:10 pm
Trying your shell commands, I run into an error on
make clean
And looking at the file, I find that "make clean" only removes some files (*.o)
Further inspection suggests that running
make voicecommand
should work, but I run into the following error
In file included from voicecommand.cpp:1:0:
voicecommand.h:8:27: fatal error: boost/regex.hpp: No such file or directory
 #include <boost/regex.hpp>
compilation terminated.
Makefile:34: recipe for target 'voicecommand' failed
make: *** [voicecommand] Error 1
I've installed some of the libboost libraries using the following command:
sudo apt-get install libboost-dev libboost-thread-dev libboost-system-dev libboost-atomic-dev libboost-regex-dev
No luck. Has anyone else successfully compiled on the pi?
Nki1989
Re: voicecommand
Mon May 16, 2016 2:44 pm
Has anyone figured what to do after the voice command prompt doesn't work?? When downloading the voice command section of it it simply says voicecommand: error while loading shared libraries: libboost_regex.so.1.49.0: cannot open shared object file: No such file or directory.
I am doing this on a raspberry pi with raspbian Jesse and I have to have this sorted out today as it's the last part of a project I'm working on
Thank you so much for any help
DataManX
Re: voicecommand
Sun May 22, 2016 7:16 am
This command resolved a similar problem I was having with libboost not found that others report above.
I ran this "sudo apt-get install libboost-regex1.49.0" after I installed Voice Command following instructions here
http://stevenhickson.blogspot.com/2013/ ... e-and.html
Works like a charm.
Low84000
Re: voicecommand
Thu Jul 21, 2016 8:41 pm
For those who cannot have the older version of libboost-regex 1.49.0.
If you are in version 1.55.0
Just execute this command :
ln -s /usr/lib/arm-linux-gnueabihf/libboost_regex.so.1.55.0 /usr/lib/arm-linux-gnueabihf/libboost_regex.so.1.49.0
Hope it helps :p
Source : https://github.com/StevenHickson/PiAUISuite/issues/58
meatgrinder
Re: voicecommand
Tue Sep 19, 2017 11:24 pm
or create a link from whatever libboost regex version that you have
rottieGO
Re: voicecommand
Wed Oct 25, 2017 3:39 am
Did anyone figure out how to run PiAUISuite on Raspberian Stretch on Pi 3B with following versions
axel is already the newest version (2.12-1).
curl is already the newest version (7.52.1-5+deb9u1).
flac is already the newest version (1.3.2-1).
libboost-dev is already the newest version (1.62.0.1+b4).
libboost-regex-dev is already the newest version (1.62.0.1+b4).
libcurl4-gnutls-dev is already the newest version (7.52.1-5+deb9u1).
mpg123 is already the newest version (1.23.8-1).
sox is already the newest version (14.4.1-5).
xterm is already the newest version (327-2).
youtube-dl is already the newest version (2017.05.18.1-1).
host 9.10.3-P4-Raspbian
Installation fails at:
Would you like voicecommand to try to set itself up? y/n
maikodocty25
Re: voicecommand
Fri Oct 27, 2017 4:04 am
I tried to run all this version but still, voice command failed
I even execute this command:
make clean
voicecommand -s
https://www.abestmeter.com/ultrasonic-f ... el-sensor/
arda85835
Re: voicecommand
Sun Feb 18, 2018 6:14 pm
****SOLUTION****
You are getting this error:
ls /usr/lib/arm-linux-gnueabihf/ | grep 'libboost_regex'
Your output will be something like:
libboost_regex.a
libboost_regex.so
libboost_regex.so.1.62.0 (This number may be different, in that case update the following code)
sudo ln -s /usr/lib/arm-linux-gnueabihf/libboost_regex.so.1.62.0 /usr/lib/arm-linux-gnueabihf/libboost_regex.so.1.49.0
Callipygous
Re: voicecommand
Tue Jul 23, 2019 3:14 am
After receiving this error and following the instructions above this is the result I'm getting.
My experience in this field is extremely limited. Stupid mistakes are likely, and assistance may need to be thoroughly spelled out :P
[email protected]:~/Desktop/PiAUISuite/Install $ sudo ln -s /usr/lib/arm-linux-gnueabihf/libboost_regex.so.1.62.0 /usr/lib/arm-linux-gnueabihf/libboost_regex.so.1.49.0
ln: failed to create symbolic link '/usr/lib/arm-linux-gnueabihf/libboost_regex.so.1.49.0': File exists
DavidS
Re: voicecommand
Tue Jul 23, 2019 5:36 pm
It is good to see people working on speech recognition applications for different systems. There are those people that are unable to use other means of input for various reasons.
It is unfortunate that people are not spending the same effort on good front ends for Speech Synthesis. There are people that do not have the luxury of using verbal communication directly for multiple reasons, be it Aphasia, Vocal Mutism, Neurologic Mutism, etc. I think this is likely as common a problem as people not having good use of there hands to type.
There are those of us that rely on Speech Synthesis in order to effectively communicate. This is primarily do to how few people know sign language.
I had began to work on a front end for Speech Synthesis to speed up communications for common phrasing, by using quick tree navigation, while still allowing for custom statements to be typed just as fast as directly typing into a text editor. The trouble is that there are to many possible interfaces today, and each requires a different layout in order to accomplish the needed results (touch screen, mouse, cyberpuck, purely keyboard, eye tracking, etc).
Then I also discovered that some of the better Speech Synthesis software is not nearly as good without an internet connection (which tells me it relies on non local data for some of its translation from text to phoneme stream), this is very bad for something as critical as speech synthesis. We need to be able to rely on knowing that the speech synthesis software will produce a given quality of speech regardless of the availability of an internet connection. In some cases this can be a life critical application, something that I have learned through my medical problems first hand, so we need this life critical application to be reliable.
orignal_traveler
Re: voicecommand
Thu Nov 28, 2019 3:58 am
Thank you for the help with libboost_regex. I was able to run the install routine for voicecomand and not get that particular error. Now I am getting : voicecommand: /usr/lib/arm-linux-gnueabihf/libcurl.so.4: version `CURL_OPENSSL_3'. I searched the file libcurl.so.4 and found "CURL_OPENSSL_4" but no "CURL_OPENSSL_3". How do I get around this error now?
Thank you in advance for your assistance.
orignal_traveler
Re: voicecommand
Thu Nov 28, 2019 8:44 pm
Update on my previous post:
I found the voicecommand.cpp source file and the Makefile. When I ran make, there was an error on the version of g++ because it was hard coded in the Makefile. I removed the hard coded version of g++ and the make process seemed to work without error. When I ran the newly compiled voicecommand executable, I got the same error "CURL_OPENSSL_3 not found".
Return to “Off topic discussion”
