why does my infrared tv remote secretly use wifi?
Posted: Sun May 05, 2013 10:14 pm
by morphy_richards
After watching a film on rasbmc my wife just went to change channel using the Samsung infrared tv remote and ended up scrolling up and down a rasbmc menu instead.
Which seems a little odd when you consider she appears to have been controlling a raspberry pi hidden behind the telly with nothing other than a WiFi dongle attached to it. Is she a witch? Is this grounds for divorce?
Re: why does my infrared tv remote secretly use wifi?
Posted: Sun May 05, 2013 10:31 pm
by rurwin
It's wonderful when technology does that to you. I remember a similar experience with a slot-racing setup that supplied power to a car even when the transformer was disconnected. Magic is real.
Although in this case, there is probably a more mundane explanation. I'm no expert, but I believe I have heard tell of a back-channel on HDMI that passes IR commands back to the signal source.
BTW: never build a slot-racing circuit with only one cross-over.
Posted: Sun May 05, 2013 10:37 pm
by rpdom
I suspect it is the CEC signal from the TV being passed via HDMI to the Pi.
http://en.wikipedia.org/wiki/Consumer_E ... ontrol#CEC
Posted: Mon May 06, 2013 6:15 am
by morphy_richards
So It's quite common? Happens to others? Does it happen reliably enough to warrant writing some software to harness it and allow you to control the rpi with the normal tv remote instead of an Android app on a phone?
Posted: Mon May 06, 2013 6:32 am
by Paul Webster
it is such a good idea that it (CEC) has been included since very early days of XBMC on RPi.
Posted: Mon May 06, 2013 6:33 am
by ghans
It is common , and i believe this feature of the Pi has been
advertised by XBMC devs before. I can not vouch for reliability
though , the initial problems i heard of might've been solved
by now.
ghans
Posted: Mon May 06, 2013 7:35 am
by morphy_richards
So it has.
http://www.foo.co.za/raspbmc-control-xb ... g-hdmi-cec
Clever stuff, whatever will they think of next!
