barakuda28
Re: "Power-ON-on-power-fail" functionality?
Sat Mar 17, 2012 7:59 pm
I intend to use the Raspberry Pi as a server and I would like to know if it has "Power-ON-on-power-fail" functionality, or I will need a UPS for it?
Stupid question - does it have something like BIOS? I was not able to find any information about that...
Kernel
Sat Mar 17, 2012 8:38 pm
if you mean will it turn itself back one - as it has no power button when the power comes back on I guess it will boot up and run whatever startup options are configured
reiuyi
Sat Mar 17, 2012 9:26 pm
The device doesn't actually have a standby or "off" mode. It's always on when powered on. To answer your question: yes the raspberry pi will switch on again after a power failure, though there is a chance it'll have corrupted part of the filesystem if it was writing. For like 10 dollars you can buy one of those "emergency back up batteries for cellphones", even a really cheap one connected parallel to wall-power would supply the raspberry pi with half an hour of power. A bit of logic would even trigger it to shut-down automatically if you use the GPIOs to measure if wall-power is "on"
I guess when you try to power it down in the operating system it should say "it's now safe to shut down your computer" OH THE NOSTALGIA
A bios is a bootloader, this is supplied on the SD card. It's on the fat32 partition if you burn one of the ISOs from this site onto an SD-card. Part of the bootloader is the GPU code.
barakuda28
Sat Mar 17, 2012 10:10 pm
So, if I use an SD card of my own, the bootloader will come from the OS I use (downloaded from the site). Did I got this right?
Joe Schmoe
Sat Mar 17, 2012 10:20 pm
Look for, find, and read the thread entitled "config.txt".
It reveals all about the boot sequence.  The short answer to your question is:  The first stage is something called "The Blob" (see: Steve McQueen movie of the same name for further details).  You cannot modify the blob.
Kernel
Sat Mar 17, 2012 10:46 pm
Actually I just had a great feeling of nostalgia on being reminded of that screen - oh those were the days!
Chromatix
Sun Mar 18, 2012 7:39 pm
I modded a couple of Windows computers to read:
It is now safe to start using your computer.
The key to knowledge is not to rely on people to teach you it.
Return to “Off topic discussion”
