XAPBob
Re: Cheapest ethernet/wifi based *anything* ??
Wed Mar 14, 2012 11:38 am
With Pi arrival day drawing closer I've been thinking about a number of things, but many of them require some sort of comms from a simple sensor/actuator.
Most of my house has Cat5, but many people won't
What's the cheapest (and lowest power if poss) simple comms device we can find?
It's disturbing that I keep returning to the Pi as the cheapest option - and it's too high power for many of my thoughts.
meltwater
Wed Mar 14, 2012 11:44 am
There a lots of chips which now have Ethernet built in if that is what you are looking for, probably a few of the PIC chips would do.
Is that what you mean?
______________
http://www.themagpi.com/
A Magazine for Raspberry Pi Users
Read Online or Download for Free.
My new book: goo.gl/dmVtsc
Meltwater's Pi Hardware - pihardware.com
Like the MagPi? @TheMagP1 @TheMagPiTeam
XAPBob
Thu Mar 22, 2012 11:23 am
Yep...
Basically anything that can do ethernet and a handful of little things (i.e. trivial compute cf+ IP) with a GPIO or similar.
rurwin
Thu Mar 22, 2012 12:15 pm
That's why millions of people want to get their hands on one -- They are a lot cheaper than the existing options.
Ethernet is quite expensive to implement, you could consider Zigbee, although I have no experience of it. It is designed for low power, low cost applications.
hippy
Thu Mar 22, 2012 1:12 pm
That would be some sub-$1 microcontroller linked to others via some sort of multi-drop serial network that perhaps also supplies power.
But what you actually need depends on what you want to do.
mcb1
Fri Mar 23, 2012 10:44 pm
Not sure if this is what you're after, but offers one solution.
http://arduino-direct.com/suns.....#038;p=243
There's also these if you want wireless.
http://arduino-direct.com/suns.....#038;p=188
add a $4 328 chip and you have a lot of possibilities.
Mark
rurwin
Fri Mar 23, 2012 11:32 pm
Thanks to the BBC's coverage of the RaspPi, I came across this.
There's a couple of boards there, similar to the RaspPi but with enhanced networking and much reduced RAM.
The price is also similar to the RaspPi.
[email protected]
Sat Mar 24, 2012 2:57 pm
XBee? Failing that, there are some other lower powered stuff to take rs232 and transmit it wirelessly using the various license-free bands avalable. XBee is fairly low power, but you need power to transmit data over a distance and to bounce off walls, go through doors, etc.
And occasionally you get stuff like this:
http://www.ebuyer.com/290691-t.....-tl-mr3020
which you can re-flash with open-wrt... I really don't think you'll find a cheaper Wifi/Ethernet router than that right now (£11.13)
Gordon
Gordons projects: https://projects.drogon.net/
Return to “Off topic discussion”
