W. H. Heydt
Python 2 EoL...at least in theory
Wed Apr 22, 2020 4:24 am
https://www.theregister.co.uk/2020/04/2 ... 2_release/
Some companies are--apparently--planning to keep it going, though.
Imperf3kt
Re: Python 2 EoL...at least in theory
Wed Apr 22, 2020 6:40 am
I recall this being discussed some months ago.
55:55:44:44:4C
52:4C:52:42:41
Wed Apr 22, 2020 8:45 am
Great. One down, one to go. Then we will be free of Python :)
The end of Python 2 has been intensely discussed since the introduction of the new language Python 3, 12 years ago!
jahboater
Wed Apr 22, 2020 9:00 am
It will never go away while typing "python" in most distro's still gets you Python2
Pi4 8GB running PIOS64 Lite
Imperf3kt
Wed Apr 22, 2020 10:31 pm
My memory isn't failing me, for once...
viewtopic.php?f=32&t=249393&p=1528073#p1522670
55:55:44:44:4C
52:4C:52:42:41
drgeoff
Wed Apr 22, 2020 11:46 pm
Theory and practice are not always the same.
W. H. Heydt
Thu Apr 23, 2020 12:37 am
In theory...they are. In practice...they aren't. (I wish I lived in Theory...everything *works* in Theory.)
davidcoton
Thu Apr 23, 2020 10:45 am
Does Theory account for the behaviour of gyroscopes yet?
Or the missing mass of the universe? Dark Matter Identified :!:
Thu Apr 23, 2020 11:32 am
Ah, I get it, the dark matter is made of gyroscopes.
That is why stars are orbiting their galaxies at the wrong speed.
bensimmo
Thu Apr 23, 2020 12:45 pm
I think the latest Ubuntu has it removed and debian based setups will have at the next major update.
All good, but given they've had years and years to move it over, why did it take so long. not to worry
anyway, it will come eventually.
jahboater
Thu Apr 23, 2020 12:50 pm
Good!
for now:
alias python=python3
does the job, or use the shebang line
Thu Apr 23, 2020 1:41 pm
Given that they created an incompatible, syntactically different, language that was not backwards compatible I think they should have given their new language a different name.
"Brian" for example.
That would have saved a lot of confusion and wasted human life over the years. And we could have all happily continued with Python and ignored Brian.
GlowInTheDark
Thu Apr 23, 2020 1:55 pm
It is my understanding that there is one particular piece of software that is widely used (many if not most of the participants on this board have probably used it; I use it several times a day) that is Python2 based and is so huge that converting it over would be unfeasable (sp?).
As long as that piece of software is in use (which is to say, forever), Python2 cannot completely go away.
GitD's list of things that are not ready for prime time:
1) IPv6
2) 64 bit OSes
3) USB 3
4) Bluetooth
Paeryn
Thu Apr 23, 2020 2:42 pm
Poor Brian, was he just a very naughty boy for messing with python?
They did give the updated python a new name, python3, a total rename just because of a few language changes would be ridiculous. I don't remember there being long-running complaints back when python2 started replacing python, people just fixed their code to account for the breakages (probably fewer than from 2->3 but they were there) and got on with using the newer version to the point that python2 effectively became python and no-one uses the original python anymore (I can't remember if 1.0 broke 0.9, I was new to it back then).
Fri Apr 24, 2020 12:58 am
...They did give the updated python a new name, python3,
I don't buy the idea of "Python3" being a new name. It's clearly meant to indicate a version change in Python.
...a total rename just because of a few language changes would be ridiculous....
Would it? How much a change in a languages syntax and semantics would you require to say "that is a different language". There is a reason "C++" is not "C".
As it stands Python 2 programs do not run under Python 3. That smells like a different language. Not only the the changes are not so trivial and some are impossible find easily without looking at all your code carefully. This cannot be automated. They may be no errors from the run time.
That was a long time ago. There were far less Python users around. There was far less Python code in existence. There was far less Python as a dependency of other things. It was a happier time.
Imperf3kt
Fri Apr 24, 2020 1:15 am
I recall trying to use python 2 code in a python 3 script... It did work, but it didn't do the same thing as it did in python2
Skills you learn with python2, may not work the same, or at all in python 3, and vice versa
55:55:44:44:4C
52:4C:52:42:41
ehem
Fri May 22, 2020 2:57 am
They can almost certainly be automated. Worst case, write a Python 2 interpreter in Python 3 and you should be able to continue running Python 2 within Python 3. I haven't done anything very gnarly with Python, but 2 and 3 are mostly fairly compatible.
At the most basic level, Python 3 shares rather a lot of Python 2's characteristics. I ran across a presentation of someone talking about all the features they would include to make the most annoying programming language possible. Syntactically significant whitespace was near the top of the presenter's list.
One tab to rule them all. If you like 4 space indentations, set your tab stop to 4 spaces. Heck, even covers the person who likes 5 space indentations.
W. H. Heydt
Fri May 22, 2020 4:10 am
You're too young to have done much of anything with languages that were originally written with unit records intended...like FORTRAN II or COBOL. Or SPS II, Autocoder, or ALC. Or--shudder--RPG.
gkreidl
Fri May 22, 2020 5:42 am
No, Heater's right. Although there are some tools for conversion, you will have a lot of bugs/problems. Here's a simple example:
Let's assume "d" is a dictionary.
k = d.keys()
k.sort()
will run in Python and produce a sorted list of keys.
In Python3 it will produce an error, because the keys() function now returns an iterator and not a list any more.
No kind of conversion tool will fix this.
Minimal Kiosk Browser (kweb)
jahboater
Fri May 22, 2020 8:06 am
Here is another example - a basic math operator has changed its semantics.
... and this time it wont produce an error, just silently return the wrong answer!
 $ python
Python 2.7.12 (default, Apr 15 2020, 17:07:12)
>>> 2/3
0
$ python3
Python 3.7.2 (default, Jan  9 2019, 15:51:37)
>>> 2/3
0.6666666666666666
Fri May 22, 2020 8:11 am
I do wish people would not speak so stridently on matters they know nothing about. This is why the internet is full of incorrect junk.
If you do your research you will find that automating conversion of the Python 2 language to the Python 3 language is hard to impossible. see gkreidl 's example above for starters.
If such a conversion were possible the tools(s) to do it would have been created a decade ago. They could have been part of a Python 3 installation. This whole 2 vs 3 problem would have been resolved ages ago.
Interpreting Python 2 from within Python 3 is hardly going to be a practically working solution.
Sure it does. Problem is it's impossible to tell which is which from reading the source so conversion is hard.
It's not the TAB width that is the problem. Although of course nobody should use TAB characters in their code. The whole idea of using white space as block delimiting is daft. And, if you are going to do it so as to remove weird braces and such then do a proper job and don't require that stupid redundant ":" everywhere.
I big issue is that it is that with the lack of a type system and other high level language features that help ensure correct code it is so hard to tell if your python programs work correctly in the first place that nobody wants to touch them simply to change language to Python 3.
Yes Python 3 is a different language. It has a different syntax and semantics than Python 2, that is what makes languages different, and is not backwards compatible. See above.
scotty101
Fri May 22, 2020 8:18 am
Boo hoo. Heater thinks python sucks.
Change the record.. python's popularity speaks for itself.
Fri May 22, 2020 8:22 am
You're showing your age. I've not heard or used the term "unit record device" (for card readers, card punches and line printers) in more than 30 years.
BTW, I thought python2 had a happy death on 1st Jan 2020.
Fri May 22, 2020 8:44 am
If you ever find you have been around the block a few times and have had to program in more languages than you care to remember you will likely come to the conclusion that all programming languages suck.
We know this to be generally true because new programming languages sprout like weeds. Why would so many talented software engineers, waste their time trying to define and build new programming languages if they were happy with anything that existed already?
Since when has popularity been a measure of the quality of anything?
Also note that for most things people do with Python they are actually depending on libraries written in other languages. From driving GPIO to OpenCV to Tensorflow etc, etc, etc.
jahboater
Fri May 22, 2020 9:10 am
Of course, rarely.
But it is a measure of the practical usability of the language for real world applications.
In this case universal availability, vast library resources, extensive knowledge base, etc etc.
Wide exposure means less bugs.
Return to “Off topic discussion”
