Forum editor centers text
Posted: Mon Jul 15, 2019 4:21 pm
by fd_
I hope this is the right sub-forum to post about the forum itself:
For a few months now, the forum's post editor is center-aligning text for me. This makes writing a post a bit inconvenient. I'm using Safari Version 12.1.1 (14607.2.6.1.1) on macOS 10.14.5.
Screenshot:
Is this intended behaviour?
Re: Forum editor centers text
Posted: Mon Jul 15, 2019 4:36 pm
by W. H. Heydt
It's not what happens for me. You probably have set something somewhere. Check your profile settings.
Posted: Mon Jul 15, 2019 4:41 pm
by fd_
I just had a look through my profile settings - couldn't find something relevant there. Are you using Safari as well?
Posted: Mon Jul 15, 2019 4:43 pm
by Heater
Never seen that happen. Not on Windows or Linux with Chrome or Firefox.
Could even be a useful feature some times!
Posted: Mon Jul 15, 2019 6:17 pm
by Andyroo
This is from Safari 12.1.1 on 10.12.6 (a bit behind :roll: ) using the RPi style and its fine.
Screenshot 2019-07-15 19.16.29.png (33.46 KiB) Viewed 3258 times
I'll post this and swap to raspberry_pi
Posted: Mon Jul 15, 2019 6:21 pm
by Andyroo
I hate this layout !
But its working so I'm going back to pro-silver :lol:
No its not - well the text is correct but I cannot add attachments - very odd...
High ho pro-silver away (with these odd colours)
Posted: Mon Jul 15, 2019 6:23 pm
by Andyroo
Typical - just 'cause it did not work first time I try twice and it takes both BUT DOES NOT SHOW IT ON MY SCREEN!
Anyway, back to the OP post - the issue does not seem to be in Safari unless the OS has an impact (possible as webkit is OS rather than Safari).
Maybe a log out, clear cookies for the site and log back in? (Sorry sounds like a turn off / back on again fix :oops: ).
Posted: Mon Jul 15, 2019 7:03 pm
by fd_
I just logged in in a new private window, which should remove cookies from the equation. Still center-aligned though. Also, just tried Chrome and it's properly left-aligned there, so it's not linked to my profile.
Posted: Mon Jul 15, 2019 7:09 pm
by DougieLawson
If you need a non-proportional font and tabs that don't get mushed to the left use [code] stuff goes here[/code] tags.
Like
     mushed to the
left use [ code]stuff goes here[ /code] tags.
Posted: Mon Jul 15, 2019 7:13 pm
by fd_
If you need a non-proportional font and tabs that don't get mushed to the left use [code][/code] tags.
Like
     mushed to the
left use [b][[/b][b]code]
[/b] tags.[/code]
Unless I misunderstood your post, you're suggesting ways to format forum posts. However, the problem I'm seeing is that text in the editor itself (the 'source code' of the post) is always center-aligned, as displayed in my screenshot above :? :D
Posted: Mon Jul 15, 2019 7:15 pm
by DougieLawson
That's got to be a feechur of your web browser.
I don't get that on Win10 with Google Chrome or Firefox.
Posted: Mon Jul 15, 2019 8:40 pm
by Andyroo
This is where its odd - I'm running the same version of browser but an older operating system and I do not see it :?: :!:
Using the 'webkit normal' download from here gives me:
Your browser uses WebKit.
Your WebKit version is at least 418.1.
Your WebKit version number is 605.1.15.
Your WebKit version is not a nightly build.
Version information:
0: 605
1: 1
2: 15
isNightlyBuild: false
You are not surfing Mobile.
I would have thought the private may have solved it - if the webkit is the same them maybe AV / Ad blocker impacting...
Posted: Thu Jul 18, 2019 10:00 am
by fd_
0: 605
1: 1
2: 15
I'm seeing the exact same version information there - very strange :? :?:
Posted: Wed Oct 02, 2019 12:32 pm
by fd_
The recent Safari 13.0.1 (14608.2.11.1.11) update fixed it now, so it must have somehow been related to the browser :D
Posted: Wed Oct 02, 2019 12:55 pm
by Andyroo
Still not seen this though I have jumped to Mojave on one but of Apple kit.
Wonder if it’s an extension clashing?
Posted: Wed Oct 02, 2019 12:58 pm
by fd_
Only extension I have installed is https://apps.apple.com/app/pipifier-pip ... 4471?mt=12
Posted: Wed Oct 02, 2019 1:02 pm
by Andyroo
Not on the Mojave box today so cannot check the version but at least you are going :D
