scruss
PARI/GP Computer Algebra System: gp2c can't produce executables
Mon May 06, 2019 4:05 am
Heater wrote:
Sun May 05, 2019 12:49 pm
Can you show how to use gp2c to make your solution an actual stand alone executable?
I'm not sure it can, but I'd really like to be proved wrong.
Background: PARI/GP is a computer algebra system that can use arbitrary precision numbers. There was a long-running learning challenge to see what systems that could run on a Raspberry Pi that were capable of calculating Fibonacci(4784969), a million-digit number. The series is defined as:
Fibonacci(n) = Fibonacci(n-1) + Fibonacci(n-2),
where:
	Fibonacci(0) = 0
	Fibonacci(1) = 1
A number of solutions were listed here: https://github.com/ZiCog/fibo_4784969
You can also calculate it using:
Fibonaacci(n) = (((1 + sqrt(5)) / 2)^n) / sqrt(5)
I'd previously listed a solution that worked quite well. This runs on a Raspberry Pi Zero even fairly quickly:
$ time gp -s $((128*1024**2)) -q fibo.gp |tail -1 | head -c 33 ; time gp -s $((128*1024**2)) -q fibo.gp |tail -1 | tail -c 40
1.0727395641800477229364813596225
real	0m26.910s
user	0m26.113s
sys	0m0.256s
4856539211500699706378405156269 E999999
real	0m27.160s
user	0m26.150s
sys	0m0.233s
You can produce compiled versions, but they don't appear faster or be able to stand alone. Here's a log of compiling it:
$ sudo apt install pari-gp pari-gp2c
 $ cat fibc.gp
sudo apt install pari-gp2c
gp2c-run -g -W fibc.gp
fibc(n) = (((1 + sqrt(5)) / 2)^n) / sqrt(5)
$ cat $bigfib.gc
\r ./fibc.gp.run
\p 1000000
allocatemem(134217728)
print(fibc(4784969))
quit
$ gp2c-run -g -W fibc.gp
 $ cat
 $ cat
 $ time gp -s $((128*1024**2)) -q bigfib.gp |tail -1 | head -c 33 ; time gp -s $((128*1024**2)) -q bigfib.gp |tail -1 | tail -c 40
  ***   Warning: new stack size = 134217728 (128.000 Mbytes).
real	0m27.008s
user	0m26.086s
sys	0m0.330s
real	0m26.698s
user	0m25.962s
sys	0m0.367s
$ cat fibc.gp.run
install("init_fibc","v","init_fibc","./fibc.gp.so");
install("fibc","D0,G,p","fibc","./fibc.gp.so");
$ cat bigfib.gp
\r ./fibc.gp.run
\p 1000000
quit
real	0m27.008s
user	0m26.086s
sys	0m0.330s
real	0m26.698s
user	0m25.962s
sys	0m0.367s
Re: PARI/GP Computer Algebra System: gp2c can't produce executables
Tue May 07, 2019 4:20 am
Well, never mind, building executables from pari-gp was just a thought.
I've added your pari-gp solution to the fibo(4784969) challenge repository: https://github.com/ZiCog/fibo_4784969/b ... gp/fibo.gp
Runs fine on my PC, fast too:
$ sudo apt-get install pari-gp
real    0m1.054s
user    0m0.859s
sys     0m0.188s
real    0m1.050s
user    0m0.797s
sys     0m0.281s
I love the way it uses a totally different technique to all our other big fibo solutions and gives a floating point result!
I should try and find the time to run all the fibo(4784969) challenge entries on my Pi 3 and tabulate the run times. Not that performance was the main point of the exercise. I could include other useless stats, like lines of code etc...
Return to “Off topic discussion”
