John_Spikowski
Re: Why Avoid BASIC on RPi?
Fri Apr 05, 2019 4:29 am
What version of the Raspberry Pi are you using?
My examples are running on Raspian full NOOBS with a RPi 3 B.
Can someone else verify what scruss is seeing?
John_Spikowski
Fri Apr 05, 2019 4:43 am
For grins, would you mind trying the apt DEB install? Use scriba instead of sb.
Gavinmc42
Fri Apr 05, 2019 4:57 am
However you have a bit of a hard sell there. We have not been looking for "glue" languages. We have had dozens of them for decades: Awk, Perl, Python, PHP, Javascript, BASH, others I have no doubt forgotten.
Er, I'm looking for "glue".
Working on my own OS in Ultibo, after reading lots about OS's I came to conclusion I'm really looking for is "glue".
Ultibo gives me all the low level pieces and there is some shell stuff and I have done some simple extensions.
But what I think I am looking for is a Bash shell script thingy to join the pieces together.
Pretty much had my fill of OS books, need some Shell books?
Anyway ScriptBasic will get a try on my Linux/Pi boxes on the weekend, Win10 Geany permissions just stopped me :(
I'm dancing on Rainbows.
jahboater
Fri Apr 05, 2019 6:53 am
What is the package called?
"sudo apt install scriba" fails.
Fri Apr 05, 2019 7:26 am
Clearly scriba is not in the Debian/Raspbian repos.
I guess it's something like:
dpkg --install scriba-v2.0b1-1_i386.deb
As per the instructions I found here: http://scriptbasic.com/texi/ug/ug_3.2.html
I have no idea where it comes from or if there is a Raspi/ARM version.
scruss
Fri Apr 05, 2019 11:19 am
Raspberry Pi Zero. I suspect you need to change your build options so you're not creating binaries that will only run on a Raspberry Pi 3.
You either need to:
  • support all Raspberry Pis running current Raspbian; or
  • make it abundantly clear that this will only run on some Raspberry Pis.
jahboater
Fri Apr 05, 2019 1:38 pm
It usually says "Illegal instruction" if you try to run a Pi3 binary on a Pi Zero.
Segfault is just a plain bug!
John_Spikowski
Fri Apr 05, 2019 2:34 pm
sudo apt install ./scriptbasic-2.1-linux-armhf.deb
Please read the post on the ScriptBasic forum where you downloaded the install file.
This will also installed the dependencies.
John_Spikowski
Fri Apr 05, 2019 2:41 pm
Good to know that not all RPi's are code compatible.
jahboater
Fri Apr 05, 2019 3:05 pm
The Pi Zero is ARMv6, whereas the Pi3 models are ARMv8.
Fri Apr 05, 2019 3:10 pm
Code compiled to run under Raspbian on a Pi Zero (or Pi 1) will run on any Pi released so far.
PeterO
Fri Apr 05, 2019 3:16 pm
It's not a good sign that you are only learning about this now !
PeterO
John_Spikowski
Fri Apr 05, 2019 3:30 pm
I just ported ScriptBasic to the RPi less than a month ago when I bought my first RPi. I'm still learning about the limitations of the ecosystem.
John_Spikowski
Fri Apr 05, 2019 4:13 pm
I ported ScriptBasic to Android (Samsung Galaxy Tab 2 10.1) years ago. I can't remember what version of the ARM chip was used back then.
John_Spikowski
Fri Apr 05, 2019 5:15 pm
If someone with a RPI Zero would be willing to recompile the ScriptBasic source on that platform it would be much appreciated.
Use the cleanup branch in the SB-DEV sandbox repo.
There are scripts to create the AppImage and DEB. Please send me a zip of the resulting bin directory to [email protected] for testing on my RPI 3 B.
John_Spikowski
Fri Apr 05, 2019 6:07 pm
ScriptBasic Build Notes:
Use the setup script in the root source directory to build the binaries for language and extension modules. First time you will be asked to associate a Perl directory with the build system. Use sudo for the command shown.
The SciptBasic build system creates its headers and documentation from scratch using the C source code. The compiled results are put in a newly created bin directory.
I don't know of any toy BASIC languages that goes to this extent.
FYI: ScriptBasic only has one source tree for all platforms. (Windows, Linux, IOS, RPi, Android Linux and a bunch of embedded OSs)
ejolson
Sat Apr 06, 2019 3:06 am
Where is the cleanup branch? Where is the DEV sandbox repository? I can't compile anything if I can't find the code.
John_Spikowski
Sat Apr 06, 2019 3:24 am
GOTO ScriptBasic.org/forum and click on the sandbox graphic in the upper right corner. The cleanup branch is under master.
Sat Apr 06, 2019 3:25 am
Dev version of scriptbasic is here: https://sandbox.allbasic.info:8181/scriptbasic/sb-dev
John_Spikowski
Sat Apr 06, 2019 3:39 am
Thanks for posting the direct link as well.
ejolson
Sat Apr 06, 2019 4:12 am
I tried both master and cleanup. With master there is a missing syntax.h file but with cleanup all the headers are missing. It would appear the headers are supposed to be generated by the perl setup.pl script. However, running that script results in
This is unix cwd=/home/username/sb-dev-cleanup/
The jamal module esd.pm is not installed.
You have to install it before running any
kind of ScriptBasic source compilation.
The module is needed to compile source
documentation. This is a MUST.
To install esd.pm become root on UNIX,
or just have write privilege for the
directories where the Perl modules are
(this is the 'source' directory of ScriptBasic)
and run
perl jamal.pl -i
interactively answering the program questions.
and I'm not prepared to scribble all over the root filesystem on the current system. I might start over with a fresh (throwaway) install and try again, but that's all for now.
John_Spikowski
Sat Apr 06, 2019 4:30 am
I assume you installed the dev dependencies referred to in the README.MD? (see bottom of the file listing)
sudo perl jamal.pl -i
Then select the Perl path by selecting the number next to it. This is a one time deal.
Then run ./setup again. and everything should compile and the binaries resulting in the bin directory.
I normally delete the bin directory before starting a new build.
scruss
Sat Apr 06, 2019 12:41 pm
Modifying the system Perl installation outside a perl* module on Debian/Raspbian is a strict no-no. You can very easily render the system unusable. Debian uses Perl for many of its package admin functions, and if the Perl subsystem left in a state that's outside Debian's control, the dpkg system can fail.
jamal isn't on CPAN, so I'm not feeling confident that it's had too many eyes on it. The Perl install scripts for scriptbasic are … interesting. Peppered with backticks (so executing arguments, in some cases even passed strings, as root when in install mode) and installing in a mix of /usr/bin and /usr/local, I'm not sure I'd want to run these on anything but a sandbox system. I'm also not wild about having yet another dotfolder (~/.scriba) in my home directory: this is what ~/.config or ~/.local is for.
John_Spikowski
Sat Apr 06, 2019 3:33 pm
This build system has worked flawlessly for 20 years. Commercial use for as long. I have never heard of ScriptBasic screwing up anyone's system.
Thanks for giving SB a try.
@All
I'm still looking for someone with a RPi Zero to send me their bin directory for me to test on my RPi 3 B.
ejolson
Sat Apr 06, 2019 4:12 pm
I'm in favour of hidden configuration folders and files in the home directory. The other extreme are programs that automatically create non-hidden subdirectories called Desktop, Downloads, Documents, Pictures, Public, Templates and Videos.
I've now download the latest Raspbian image. Hopefully those ScriptBasic setup and installation back ticks won't bite and aren't carrying Lyme's disease if they do.
Return to “Off topic discussion”
