KanoMaster22
Speaker Wattage and Resistance Questions
Tue Sep 25, 2018 4:54 pm
Just a quick question. If a tutorial says use a 8 ohm 1 watt speaker does it matter if I use a speaker under these numbers? For example would it matter if I used a 2 ohm 0.6 watt speaker.
Thanks,
Louis P
Burngate
Re: Speaker Wattage and Resistance Questions
Tue Sep 25, 2018 5:46 pm
If the amplifier driving it is designed for no less than 8 ohms, then it may well die if you connect a 2 ohm speaker.
If the amplifier doesn't die, then it may well kill the speaker.
FTrevorGowen
Tue Sep 25, 2018 6:15 pm
+1
Possible solutions:
Use four of the 2 ohm speakers in series if you have them (total resistance 8 ohms, if the amp is delivering 1W that's 0.25 per speaker - but whether a "good" sound/volume exists is another matter)
Use a 5.6 ohm 1W resistor in series with the 2ohm speaker - but don't expect much volume ....
Trev.
LTolledo
Wed Sep 26, 2018 11:36 am
KanoMaster22 wrote: For example would it matter if I used a 2 ohm 0.6 watt speaker.
KABOOOM! It will kill the speaker at full volume! But will probably survive if you keep the volume 25% and below. And dont expect good sound quality...
You might be tempted (and probably itching already ;) ) to try.... but do it at your own risk..... :!:
Some people be like:
KanoMaster22
Fri Sep 28, 2018 6:02 am
Thanks for the help everyone. What would happen if I used a 16 ohm 0.5W speaker?
Fri Sep 28, 2018 7:09 am
That would be safe, but it would be quieter than the 8 Ohm speaker.
Burngate
Fri Sep 28, 2018 8:16 am
Amplifiers, like a lot of things, are voltage sources - they attempt to give a constant voltage whatever the load, up until too much current kills something.
It might be worth your while learning about Ohm's law - that's about volts, amps and resistance and how they relate to each other.
Also, how volts and amps relate to power.
Two equations: V = I * R and P = V * I
Obviously, V stands for Volts and voltage, P stands for power in Watts, and R is resistance in Ohms, but why on earth is I used for current in Amps? - if you find out please let me know!
jahboater
Fri Sep 28, 2018 8:48 am
Yes.
It would be 3db quieter which you may not hear.
(That is, the power would go down by half - which may be a good thing if your amp is > 0.5W).
Adding resistors or using multiple speakers in series will affect the sound quality (damping factor) but again, my guess is you wont hear the difference.
Mortimer
Fri Sep 28, 2018 9:17 am
Is it worthwhile mentioning that a speaker is not 8 Ohms 'resistance' (or 2 Ohms or whatever), it is 'impedance'. Series connection of speakers of the same type will in all likelihood work in the way suggested, but different speakers might not. The Impedance figures are at a specific frequency, usually 400Hz. The Impedance characteristics away from 400Hz could vary quite significantly, hence why speaker cross-over design is quite difficult and considered to be an 'art' by some.
As already stated, going higher in impedance (16 Ohms) means a reduction in speaker sensitivity, i.e. it's response to a particular peak to peak Voltage level of the driving signal, and hence the safer direction to go in.
The purpose of a little toe is to ensure you keep your furniture in the right place.
jahboater
Fri Sep 28, 2018 10:04 am
Yes indeed.
See these graphs ...
https://www.google.co.uk/imgres?imgurl= ... AHoECAcQBg
There will be no crossover in these little speakers, so I guess its just inductance and resistance.
The simple notional 8ohms / 16ohms is probably good enough for the basic discussion above ...
Paeryn
Fri Sep 28, 2018 11:53 am
I is what Ampère used for Current Intensity (Intensité de courant). Here in the UK we originally used C but we had swapped over to using I by the turn of the 20th century.
W. H. Heydt
Fri Sep 28, 2018 1:47 pm
And the use of "i" for current is why, in electrical and electronic engineering, the square root of -1 is "j".
ejolson
Fri Sep 28, 2018 4:29 pm
What you say is true if the amplifier output stage uses transistors but not true if vacuum tubes are used. For tubes a two ohm impedance represents less load than eight and is subsequently easier to drive.
KanoMaster22
Fri Sep 28, 2018 4:46 pm
Thank you again everyone! I understand how to speakers work a lot better know.
Thanks,
LouisP
jahboater
Fri Sep 28, 2018 6:59 pm
They usually have an output transformer, so can easily match any impedance the designer chooses.
Sometimes there is a choice - via "taps" into the transformer.
Return to “Off topic discussion”
