RAVR
GPU Hardware and/or Software Suggestion
Sat Jun 09, 2018 5:36 am
I would like to suggest a hardware change to the RPi that allows for the GPU to act as a NPU using the OpenCL software driver support.
I know that this may be difficult or near impossible but it was a thought.
Thank you for reading my post.
Re: GPU Hardware and/or Software Suggestion
Sat Jun 09, 2018 7:48 am
YAPP&UT
Note:Having anything remotely humorous in your signature is completely banned on this forum.
ghans
Sat Jun 09, 2018 10:52 am
It seems unlikely that the VideoCore IV GPU will ever support the Standard OpenCL profile correctly with great performace.
In the meantime, you can play around with the embedded profile of OpenCL on the Raspberry Pi:
viewtopic.php?t=194952
Both correctness and performance (!) have room for improvement ....
ghans
mic_s
Sat Jun 09, 2018 2:45 pm
Lot of options :
option 1 :
As ghans mentined: room for improvement
In the meantime option 2 may be of value :
https://github.com/mn416/QPULib
(small footprint, easy and ready to run)
When it comes to performance:
option 3 :
https://github.com/nineties/py-videocore
( “QPU-assembler embedded in python”, 5-12$ pi-zero sgemm with up to 8 GFlops )
If you are interested to do experiments in gpu clustering, this very, very low cost pi zero cluster may be one more option :
viewtopic.php?f=49&t=199994
Please note: all current pis use the Videocore IV with 12 dual issue, vector processors.
RAVR
Sat Jun 09, 2018 4:08 pm
Thanks! It's going to talk myself a while to digest the information in the post: "OpenCL on the VideoCore IV!" by "doe300".
My hat's off to "doe300" for doing the work to port part of the OpenCL instruction set to the RPi.
RAVR
Return to “Off topic discussion”
