Projects to practice
Posted: Mon Nov 20, 2017 2:20 am
by zack68
Hello All,
I am new for RP applications..and I am looking for help to start with simple project using RP3, Sensors, motor Azure web services,.
I have RP3 downloaded NOOBS and I was successful to read the raw temp from the sensors.. But I need the Python basic program to understand the steps and get the visualized output in the Azure environment.
This is required as school project , How to control the flow of the chilled water to the heat exchange, means when its gets cold the motor adjust the valve on the supply pipe to reduce the water flow and monitor the input/output temps remotely .
What the purpose of using Python programming language here? I know C or VS can does the same?
Thank you
