9rpcrowe
Laptop Power problem
Mon Sep 25, 2017 1:09 pm
ok I have a laptop that was refurbished when I bought it and it came with a cheap Chinese power adapter and it didn't work well I fit that with one of my own and a little soldering but now It broke and I need a new one and I'm gonna build one cause I don't wont to spend 50 dollars on a power adapter. here are the specs
input
voltage 100 VAC- 240 VAC
1.5 - 1.6 Amps
50- 60 Hz
Output is
65 watts - 90 watts
3.34 amps - 4.62 amps
19.5 +/- 1.00 VDC
RaTTuS
Re: Power problem
Mon Sep 25, 2017 1:18 pm
bsaically don't
I'd buy one myself ,
https://www.aliexpress.com/item/19-5V-4 ... 73236.html
but YMMV on usefulness
Covfefe
9rpcrowe
Re: Power problem
Mon Sep 25, 2017 1:41 pm
did you not see the 12 to 20 days it would take I mean I need it asap and its expensive for expedited shipping
RaTTuS
Re: Power problem
Mon Sep 25, 2017 1:43 pm
buy one from a local shop , it's going to take you longer to build one if you have not done it before
and it will be a hell of a lot more dangerous
mains electricity can, and does kill
Covfefe
9rpcrowe
Re: Power problem
Mon Sep 25, 2017 1:44 pm
I live in the middle of nowhere.
also I don't have a lot of money
but I do have a lot of scrap
csnape
Re: Power problem
Mon Sep 25, 2017 2:18 pm
I am a little confused as to what the question is. Personally its sometimes best to look for a replacement PSU as they dont cost that much and if its as old as you can suggest you should be able to find a suitable replacement at low cost on amazon or ebay.
Most laptop PSU's are switch mode which means they convert AC to DC and then back into AC at high frequency which is how they get away with using smaller transformers. This makes them cheap but also they can be difficult to repair and constructing one can be quite challenging.
drgeoff
Re: Power problem
Mon Sep 25, 2017 4:12 pm
@9rpcrowe
Why have you posted here in a RPi forum and what is your question?
Your situation is nothing to do with RPi. You clearly had decided what you are going to do before posting here. And you are not accepting good advice to the contrary.
9rpcrowe
Re: Laptop Power problem
Tue Sep 26, 2017 2:41 pm
I want to build one because like I said I don't have a lot of money to spend on a power cord when all I need is just an adapter and I could make one smaller than the big bulky one from Dell. and I kinda want to learn i mean these forms are for help right this thread night not be in the Right place but I thought it would be better than nothing I have plenty of scrap like copper wire and stuff so please I've given the requirements for it.
pcmanbob
Tue Sep 26, 2017 3:42 pm
This is an example of the sort of circuit you might find in a laptop PSU. ( probably not even close to the actual one you would need for your specific laptop )
if you think you can build this from scrap then I am sorry but you are living in cloud Cuckoo land, even if you could by some miracle find all the right components you would still need a PCB to mount them on.
Please just take the good advice that has already been given and go buy one.
Please only ask questions in the forum I will not answer questions sent to me directly via PM
Remember we want information.......................no information no help
The use of crystal balls & mind reading is not supported
berrymix
Wed Sep 27, 2017 7:19 am
You should have it check at a local center. But if you're techy enough then you can try to follow @pcmanbob instruction.
alphanumeric
Fri Sep 29, 2017 11:54 am
I'm a retired electronic technician and I wouldn't tackle trying to make my own switching power supply, ever. An old style transformer style yes. If I had to, in a pinch, and I had the parts on hand. It wouldn't be pretty or very portable. It's a lot easier than a switching mode power supply though. Big transformer to take the 120 VAC down to what you need. Bridge rectifier to convert it to DC. Filter capacitor to smooth it out. Then a voltage regulator to get the exact voltage you need. Still not all that easy if your just using parts you have on hand. You'll need a multimeter, soldering iron, and some skill. Have you ever done any electronics work before? Do you have the tools on hand to remove the components you need without damaging them in the process?
drgeoff
Fri Sep 29, 2017 4:13 pm
No you could not.
Neil_Hines
Re: Power problem
Wed Oct 04, 2017 7:02 am
bsaically don't
What did you buy friend? The link you are showing its not working?
drgeoff
Re: Power problem
Wed Oct 04, 2017 11:12 am
bsaically don't
That link is working fine as I type this.
US$10.49 inc. shipping to UK for "19.5V 4.62A 90W Ac Power Adapter Charger For Dell Laptop Ad-90195D Pa-1900-01D3 Df266 M20 M60 M65 M70 7.4Mm * 5.0Mm"
Return to “Off topic discussion”
Who is online
Users browsing this forum: No registered users and 7 guests
