jmlxg
Re: 2nd PI
Tue Dec 13, 2011 9:48 pm
I think that 2nd gen Raspberry PI should use:
- Single/Dual Core ARM Cortex A7 CPU at least 700mhz
- 512MB RAM
- Lower power usage (from 2 to 3 watts down to 1 to 2 watts)
For a $25 computer the 24GFLOPS GPU might be powerful enough to play most games that can be played on ARM computers right now expect ailen-arena.
liz
Re: 2nd PI
Tue Dec 13, 2011 10:06 pm
And I think it should have wheels and come bundled with a sandwich.
If you do a bit of searching in the forums, you'll see a lot of speculation about stuff like this (and the reasons why some of it is not possible at the moment).
Director of Communications, Raspberry Pi
shiftyphil
Re: 2nd PI
Tue Dec 13, 2011 10:07 pm
Also needs a cup holder and an ice dispenser.
kme
Re: 2nd PI
Tue Dec 13, 2011 10:11 pm
Don't forget winter tires - safety first!
MystX
Re: 2nd PI
Tue Dec 13, 2011 10:22 pm
Please rename topic to "Sarcastic suggestions for R-Pi 2nd Gen specs".
Also it needs a foozball table.
tntexplosivesltd
Re: 2nd PI
Tue Dec 13, 2011 10:28 pm
Can the next R-Pi have full 3D output?
And a pony?
And a VR setup?
What about cake-making facilities?
Jessie
Re: 2nd PI
Tue Dec 13, 2011 10:36 pm
I just want it to mount to a shark and have a 5W laser. Is that too much to ask for $35?
Seriously, all that stuff will come in due time. Next year better chips will be less expensive, and if the foundation dosn't pick up that ball and run with it someone else will. That is just how semiconductors work they always get better and less expensive.
Jongoleur
Location: O'erlooking the sea, and all those effin windfarms...
Re: 2nd PI
Tue Dec 13, 2011 10:41 pm
Quote from Jessie on December 13, 2011, 22:36
Hmmmmmmmmm.....
Sounds interesting. One of these beauties?
With a RaspPi providing selachian intelligence, we could be onto a winner....
I'm just a bouncer, splatterers do it with more force.....
walney
Re: 2nd PI
Now that's just plain silly!... The laser blows the power budget on its own.
tntexplosivesltd
Re: 2nd PI
Tue Dec 13, 2011 10:42 pm
Also my signature holds true in this case:
http://www.raspberrypi.org/for.....#038;t=295
http://www.raspberrypi.org/for.....#038;t=246
http://www.raspberrypi.org/for.....#038;t=656
From http://www.raspberrypi.org/faqs:
Why doesn’t the Raspberry Pi include <insert name> piece of hardware or <insert name> sort of port?
Our main function is a charitable one – we’re trying to build the cheapest possible computer that provides a certain basic level of functionality, and this means we’ve had to make hard decisions about what hardware and interfaces to include.
jmlxg
Re: 2nd PI
Tue Dec 13, 2011 10:56 pm
Hahahah...You guys are funny. What I ask for is impossible right now I know that much. I was thinking next year that stuff should be for the most part doable.
tufty
Re: 2nd PI
Wed Dec 14, 2011 8:22 am
[embed][/embed]
RaTTuS
Re: 2nd PI
Wed Dec 14, 2011 9:28 am
2nd RPI should be another RPI bolted on top of the original - i.e. 2x everything .... but with shared address space ;-p
Covfefe
unaiur
Re: 2nd PI
Wed Dec 14, 2011 10:03 am
2nd generation RPI will be a perfect circle (also called r^2 PI). It will sport a new Broadcom chip in a new rounded package (like a watch battery) with 3 cores and one mini core (with 14.1592% of the processing power). Of course, any connector which isn't rounded will be removed. That is; USB ports will be replaced by PS/2 connectors, the ethernet port will be replaced with token ring and hdmi will be removed.
Luny
Re: 2nd PI
Wed Dec 14, 2011 12:46 pm
Look, the most important thing to get down in price for the 2nd generation is a rubber keyboard.
Luny
Asmodeus
Re: 2nd PI
Wed Dec 14, 2011 3:11 pm
No, the most important thing is 2,5inch-onboard-monitor. ;-)
Burngate
Re: 2nd PI
Wed Dec 14, 2011 5:27 pm
Quote from Asmodeus on December 14, 2011, 15:11
And a microscope 8-)
walney
Re: 2nd PI
Thu Dec 15, 2011 3:01 pm
Looks doable now, with the Gert board. (You will need some means to waterproof the board, however... and probably a very small shark.)
Willofield
Re: 2nd PI
Thu Dec 15, 2011 3:14 pm
Whats about a Flux capacitor and of course an integrated Lightsaber would be great ;)
riffraff
Re: 2nd PI
Thu Dec 15, 2011 4:03 pm
@ liz
But now we have GertBoard!!! RasPi can come rolling in - IN the sandwich on wheels - and not just a SANDWICH ON WHEELS - but a MOTORIZED, AUTONOMOUSLY CONTROLLED, GPS GUIDED, HEAT-SEEKING SANDWICH ON WHEELS. 8)
riffraff
Re: 2nd PI
Thu Dec 15, 2011 4:09 pm
@ Jessie
No. no. no. You'll simply have to make do with the GMO sea bass.
riffraff
Re: 2nd PI
Thu Dec 15, 2011 4:22 pm
@ tufty
There can NEVER be enough COWBELL.
Jongoleur
Re: 2nd PI
Thu Dec 15, 2011 7:32 pm
Quote from riffraff on December 15, 2011, 16:03
@ liz
And with flashing lights, it would be a JAM SANDWICH!!!! :o
Saunters off, nonchalantly humming the "Sweeny" theme.......
liz
Re: 2nd PI
Thu Dec 15, 2011 7:34 pm
I am only interested in your animated sandwich if it contains bacon.
Jongoleur
Re: 2nd PI
Thu Dec 15, 2011 7:37 pm
Quote from liz on December 15, 2011, 19:34
and a bit of black pudding? 8-)
