W. H. Heydt
Heart Rate monitor chip Cheaper (barely) than a Pi Zero...
Tue Dec 06, 2016 5:38 pm
http://www.newark.com/analog-devices/ad ... p/01AC4776
It's a heart rate monitor intended for wearable tech. Cost just under $5 in unit quantity.
Re: Cheaper (barely) than a Pi Zero...
Wed Dec 07, 2016 11:57 am
A bubble gum is cheaper than a Pi Zero. And about as comparable to a Pi Zero.
What are you getting at exactly?
W. H. Heydt
Wed Dec 07, 2016 7:31 pm
Heater wrote:A bubble gum is cheaper than a Pi Zero. And about as comparable to a Pi Zero.
I'm getting at that a consumer grade version of a medical device (heart monitor) is now less than $5. Add an ADC and hook it to a Pi and you've got a really inexpensive EKG machine. Not up to professional standards, sure, but probably at least as good at this particular function as a Fitbit or Apple Watch....for a great deal less.
The other thing I'm getting at is that here is a (potentially) useful device that could be made to work with a Pi Zero that, for a change, costs less than the Pi Zero itself.
Ronaldlees
Thu Dec 08, 2016 10:08 pm
W. H. Heydt wrote:http://www.newark.com/analog-devices/ad ... p/01AC4776
Very interesting device - just over $3 in 1000 count volume. It has I2C - so easy hookup.
I am the Umbrella man
hippy
Fri Dec 09, 2016 12:57 pm
W. H. Heydt wrote:Add an ADC and hook it to a Pi and you've got a really inexpensive EKG machine.
From the "heart rate monitor" description it wasn't immediately obvious that it's a lot more than that. It does look interesting and probably a lot safer than what some people come up with as DIY EKG/ECG monitors. The two lead non-driven mode, similar to Polar and other modules which strap around the chest, is probably the best and safest to start with.
mjtessmer
Re: Heart Rate monitor chip Cheaper (barely) than a Pi Zero.
Tue Dec 13, 2016 1:37 am
There is another alternative to measuring heart rate; pulse oximeter. It can also measure
percentage of oxygen in the blood. Cost as low as $11.59.
bensimmo
Tue Dec 13, 2016 8:33 am
mjtessmer wrote:There is another alternative to measuring heart rate; pulse oximeter. It can also measure
Any link to example to hook up to a Pi? Or any modified to work with the Pi. For good old datalogging and stat overload.
bensimmo
Tue Dec 13, 2016 8:34 am
Can you post the make and model, I'm blocked from there with our 'network security'
BMS Doug
Tue Dec 13, 2016 8:48 am
Manufacturer: ANALOG DEVICES
Newark Part No.: 01AC4776
Manufacturer Part No AD8233ACBZ-R7
this is a raw chip not a breakout board, 20 pin ball matrix for soldering onto your PCB.
Doug.
bensimmo
Tue Dec 13, 2016 8:56 am
Thanks, the evaluation board for the AD8233 is not a lot either, more than a Pi3 though.
http://uk.farnell.com/analog-devices/ad ... dp/2667954
Since it looks new, I guess it'll be a wait for a Alibaba special.
Return to “Off topic discussion”
