nitzan
Waveme: Free digital timing diagram drawing tool
Fri Oct 21, 2016 8:41 pm
Introducing Waveme
A new, free, GUI-based, digital timing diagram drawing software for Windows (and Linux/MacOS via Wine http://www.winehq.org/).
Waveme is intended primarily for documentation purposes,
where a diagram can be exported (stored) to an image file (PNG, BMP or TIFF) or a PDF document.
A color diagram can be converted to black-and-white, and stored into a new project file.
Waveme can be used to draw waveforms (signals and buses), gaps, arrows and labels (see attached images).
Highly customizable, with a wealth of keyboard shortcuts.
Website:
http://waveme.weebly.com
Google group for questions, bug reports, feature requests, and general discussion:
https://groups.google.com/forum/#!forum/waveme
Waveme is distributed as a single-file executable, it doesn't require installation,
and there are no changes to the registry nor configuration files.
Please note that because it is an executable file, it might be flagged by antivirus programs.
Avoid false-positive, by always confirming with Google's http://www.virustotal.com.
Hope you find it useful!
mahjongg
Re: Waveme: Free digital timing diagram drawing tool
Tue Oct 25, 2016 5:17 pm
Note that this program does NOT run on a Raspberry PI, as Wine does NOT run on a PI.
WINE Is Not an Emulator, (yes that is what the acronym means) and so doesn't emulate an X86 CPU on the ARM CPU based PI.
Still as it is primary intended to draw timing diagrams, which can be drawn for logic that CAN work on a raspberry PI, it has still its use for the PI.
nitzan
Sun Sep 03, 2017 6:24 pm
Version 1.4 is now available.
New features:
- Bus waveform:
Segment drawing is more flexible. A segment now has 3 (instead of 2) independently specified portions: Transition to level, level, and transition from level.
* This allows for a waveform to start and/or end with the level portion of a segment.
* Multiple segments can be placed back-to-back, with only the outliers having non-zero transitions. This gives the appearance of a single segment with multiple regions.
- Along arrow:
Select whether to show the right and/or left guidelines.
* This makes it possible to draw an arrow pointing in only one direction, and without guidelines around it; or
* A straight line, without arrow heads nor guidelines.
Bug fix:
- Signal and Bus waveform:
Incorrect empty segment after undo of segment deletion.
nitzan
Mon Oct 09, 2017 9:05 pm
Waveme version 1.5 is now available.
Bug fix: Gaps dialog box did not open.
nitzan
Mon Apr 02, 2018 4:54 pm
Waveme version 1.6 is now available.
New features:
- Superscript and subscript: supported in all text entries.
- Waveform name: Can be individually customized per row (font, color and alignment).
- All waveforms support segment labels, with identical and expanded customization options.
- Signal and Bus waveform, segment label vertical position: can be placed above a segment too.
- Multiple segment selection in Bus and Signal waveforms: supports duplicate, delete and move operations.
- Auto Bus and Auto Signal waveforms:
* Added support for first, multiple gap, and last segments.
* Segment labels:
- Text can surround the auto-generated numeric values.
- Supports wrap around, and initial wrapped around numeric values.
- Row copy and paste operations allow copying a row from one diagram to another.
- Title: Horizontal position can now be relative either to the whole diagram, or to the waveforms area.
- Horizontal grid lines:
* Can select not to show in Spacer Rows.
- Vertical grid lines:
* Can end on a given unit.
* Can draw groups of vertical lines with a gap in between.
* Can draw single vertical lines.
- Along Arrow:
* Option not to show horizontal line.
* Option to extend guidelines to cover arrow's own waveform.
- Aware of multiple connected monitors.
Mon Apr 02, 2018 9:35 pm
I guess it still does not run on a Pi. Why is this news here?
nitzan
Sat Apr 14, 2018 10:12 pm
Waveme version 1.7 is now available.
Use Waveme to draw waveforms of your Pi projects.
New features:
* Signal waveform: Added D (Data) segment.
* Across arrow: Arrow head can be bidirectional: Head can be drawn at the "From row" end, as well as at the "To row" end.
nitzan
Mon Jun 04, 2018 3:58 pm
Waveme 2.0 is now available.
This version includes UI changes for faster user interaction:
- Adding a new item immediately adds the item to the diagram, using default values, and then opens an edit dialog for further adjustments to the new item.
- An "Apply" button was added to all edit dialogs, General options and Waveform options dialogs. Now you can apply your changes to a diagram, while the dialog stays open, allowing you to observe and make adjustments faster.
- Row arrows are managed with a tabbed notebook dialog.
- Row labels are managed with a tabbed notebook dialog.
nitzan
Thu Sep 06, 2018 5:11 am
Waveme version 2.1 is now available.
New feature:
In Auto-bus and Auto-signal dialogs, auto-label values are not allowed to be left empty.
Bug fix:
Redraw dialog window after a change in selected font to prevent dialog box from being drawn incorrectly.
nitzan
Sun Jan 06, 2019 10:10 pm
Waveme version 2.2 is here!
New features:
- Expanded support for clipboard copy/paste operations to Bus and Signal segments, row arrows and row labels.
Now rows, segments, arrows and labels can be copied and pasted either within the same diagram or in another diagram.
- Along arrow guideline can now be from any row to any row, instead of from current row to any row.
Bug fixes:
- Row copy/paste was broken.
- Saving to a PDF file with "A4" page size and "Portrait" orientation created a "Letter" page size instead.
What's next?
I'm looking into adding analog signal drawing capabilities to Waveme, turning Waveme from a digital-only into a mixed-signal waveform drawing tool.
Please share your needs, and post some analog drawings, that you'd like to create with Waveme.
dave j
Mon Jan 07, 2019 4:44 pm
Get it to run on a Raspberry Pi. I can't see much point to you posing about it on here if you don't - most people will be looking for native applications. Looking at your web site it looks like you're using cross platform toolkits so it shouldn't be too difficult.
On the subject of your web site - why such low contrast text? It just makes it difficult for people to read.
nitzan
Tue Jan 08, 2019 1:27 am
- I've adjusted the website's font color to its max available contrast. Thank you for bringing this issue to my attention.
- Many people build projects with RP, that utilize its IO pins and comm ports, where documenting activity with timing diagrams is vital. Waveme was designed with such people in mind.
Wed Jan 30, 2019 9:40 am
This looks very nice. A couple of issues:
1) It's a Windows only program. Not much use for Pi users.
2) It's closed source.
That aside what would make it useful is for it to be able to import and explore actual wave forms as recorded by hardware simulators or from actual hardware. Being able to display FST, LXT2 files as well as standard Verilog VCD/EVCD would be great.
LukeW
Thu Jan 31, 2019 12:17 pm
If you do need to draw timing diagrams on a Pi, WaveDrom is quite nice.
Return to “Off topic discussion”
