Hi, I am having an a few issues
I have set up moonlight according to some instructions on https://github.com/RetroPie/RetroPie-Setup/issues/1082.
Strangely,this had worked for my first build bit but trying to do a second I am having a few issues.
1.Steam doesnt show in my retropie menu despite its in the config.
2. If I try running the .sh file from command line, I am getting a message saying I must pair the devices. However, if I run the moonlight string as it is from the command line it works fine.
Any ideas?
My setup is:
retropie v4.0.2
Moonlight Embedded 2.2.0
GFE 3.0.6.49
Command: moonlight stream 192.168.1.101 -720 -30fps -mapping /opt/retropie/configs/moonlight/controllername.map
Thank you.
