sirus
Salvaging Sky box for to use with Pi
Tue Jul 26, 2016 7:43 am
Hi Guys,
I about to rip out everything from an old Sky box to use the box to host my pi, hdd and other bits and pieces. I was just curious if anyone has any luck salvaging the sky parts to be used with the PI. In particular, the DvB part (for satelite tv)
Cheers.
Re: Salvaging Sky box for to use with Pi
Tue Jul 26, 2016 8:31 am
sirus wrote:Hi Guys,
Cheers.
Sky have offered several models of Set Top Boxes, but unlikely you can salvage anything apart from the Hard Drive if it has one !!!
Thinking outside the box is better than burying your head in the sand...
sirus
Tue Jul 26, 2016 9:02 am
Cool, I thought that my be the case. Thanks.
drgeoff
Tue Jul 26, 2016 10:54 am
The 3 legged IR receiver can probably be put to use if you ever want that facility on the RPi. (It will work with most remotes, not just the Sky one.)
Quis custodiet ipsos custodes?
Return to “Off topic discussion”
